Re: Porter Cable 7424XP
So if I get the griots I Will still need to get a different backing plate??
Yes, buy the meguiars 5" backing plate
Sent using Tapatalk
Why the flat pads? Why the Griot Garage DA? Im in the market for an orbital too and thought the PC was the best (since everywhere I see it is referenced). Do I really need more power?
Flat pads give u full surface contact, u need that with a DA. The Griots is way more powerful, plain and simple.
Sent using Tapatalk
Would any backing plate work for it?
To be on the safe side, I would get the backing plate directly from whatever manufacturer you decide to go with because it might mess up the counter weight and it won't orbit right (probably unlikely, but you never know). Ans also get FLAT pads. I got CSS pads and I am sorry I did.
Which Mequiars backing plate?
-http://www.autogeek.net/meguiars-5inch-rotary-plate.html
-http://www.autogeek.net/meguiars-w67da-5-inch-backing-plate.html
And why Mequiars? Does Griot's make one?
What other accessories do you recommend (other than flat pads)?
The Meguiar's backing plate works best and is recommended by Meguiar's for using the Dual Action (DA) Microfiber (MF) correction system.
The Hook and loop on the Megs backing plate are shorter, creates less heat and has been tested and proven to work with the Megs DA MF system.
Once you get the DA (I have both PCxp and Griot's...I like them both...the Griots is a good choice) you will need polishing product.
To get you started I personally would recommend:
For the Foam Pads Megs M105 and M205.
NOTE: The 105/205 work best with the Kevin Brown Method.
or
Meg Ultimate Compound and Megs Ultimate Polish
NOTE: The Ultimate products may be easier to start with.
and
Megs DA Microfiber Correction Compound
Megs DA Microfiber Cutting Discs, 5 inches
DA MF Correction system Review Link
Originally Posted by 07 z-oh-6
No, the PC doesn't come with a backing plate. Since you have to buy a BP, get the Griot's Garage DA. It's much better than the PCXP! The pinnacle pad cleaner is decent, but since it's one buy one get one free, go for it. You don't need the conditioner, just prime the pad with polish.
I knw where you're going with this...HA
GG DA/ MF DA System D300 walla paint correction!!! Nice
I don't want it to look wet, I want it to look Soaked!
Do some research om the Flex3401, sorry Mark you knw I had to say something LOL....
By mcpp66 in forum Ask your detailing questions!
Last Post: 01-10-2018, 03:51 PM
By staat.t in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 12-16-2013, 07:44 PM
By RLucky82 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 01-23-2013, 05:42 PM
By kms254 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 01-22-2012, 07:09 AM
By grandprix2plus2 in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 12-29-2011, 11:54 PM
