Thanks Thanks:  0
Likes Likes:  0
Dislikes Dislikes:  0
Results 1 to 7 of 7
Hybrid View
  1. #1
    Newbie Member
    Join Date
    Nov 2008
    Posts
    15
    Post Thanks / Like
    Overspray in door jambs
    My `07 Vette has overspray in the door jambs I've read several posts but have not decided on a solution. Of course there is a clear coat on the paint....then the overspray on top. Some options are:
    1 - Clay bar, tried that with minimal results
    2 - Thinner or mineral spirits, scary?
    3 - 4000 grit sandpaper then polish
    Since door jambs are full of contours, polish with my PC will be no fun.
  2. #2
    Super Member
    Join Date
    May 2009
    Posts
    4,837
    Post Thanks / Like
    Re: Overspray in door jambs
    First try Meguiar's Mild Clay, then try an orange ccs euro hand pad with M105 followed by a white ccs euro hand pad and M205. Meg's and Mothers' OTC clay worked for me.
    "Challenge yourself to live a better tomorrow than you did yesterday"
  3. #3
    Super Member tuscarora dave's Avatar
    Join Date
    Aug 2009
    Location
    Etters PA
    Posts
    5,403
    Post Thanks / Like
    If I were going to tackle this I would use red Clay Magic clay with APC 10:1 if that didn't do it then I would dampen a terry cloth towel with Goof off or Oops and rub the area and then if all that fails go with the damp not wet terry towel with the thinner.
  4. #4
    Junior Member
    Join Date
    May 2010
    Location
    Greenwood, IN
    Posts
    93
    Post Thanks / Like
    I've used Meguiar's agressive clay on overspray on fenders before, worked great to get the overspray. Needed a good polish afterwards, but I was planning on that anyways. Should work good on the door jambs.
  5. #5
    Newbie Member
    Join Date
    Nov 2008
    Posts
    15
    Post Thanks / Like
    The winner.....Meguiar's agressive clay. It took going over a couple of times but it did the job. I will say it is quite expensive but I only had to use maybe 1/5 of the rather large bar. A little had polishing with light pressure was the final touch resulting in a pair of smooth shiney door jambs.
  6. #6
    Super Member
    Join Date
    Nov 2009
    Location
    Pasadena, CA
    Posts
    12,615
    Post Thanks / Like
    Did you re-paint the doors or fenders?
    '03 Corvette Z06
  7. #7
    Newbie Member
    Join Date
    Nov 2008
    Posts
    15
    Post Thanks / Like
    After a lady backed into my quarter last month I had the shop replace that quarter and paint both quarters, rear bumper. deck lid and both doors. I also installed front splash guards to help stop the rock chips
    After getting the car back and polishing the whole car all is good!
Similar Threads
  1. Cleaning Door Jambs
    By Maxreed241 in forum Auto Detailing 101
    Last Post: 02-03-2018, 09:51 AM
  2. Door jambs & frames - No fun!
    By Whitewater25 in forum Auto Detailing 101
    Last Post: 01-02-2017, 11:42 PM
  3. Door Jambs
    By cleanfreak3 in forum Tricks, Tips and Techniques
    Last Post: 05-02-2016, 08:37 PM
  4. Painting Door Jambs
    By smriddler in forum Auto Detailing 101
    Last Post: 11-18-2012, 08:08 PM
  5. Door Jambs
    By wallaby-dan in forum Auto Detailing 101
    Last Post: 05-26-2011, 10:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» May 2024
S M T W T F S
282930 1 2 3 4
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31 1
