Results 1 to 5 of 5
    Sep 2009
    Sugar Land, TX
    129
    Tutorial on touch paint
    Mike, will you be able to provide us with a tutorial on how to touch up paint & "layering" it with a buffer or wetsanding
    Apr 2009
    Atlanta, GA
    687
    Re: Tutorial on touch paint
    I would be interested in seeing Mike's thoughts on this.
    Mike - Mirror Detailing - Powder Springs, GA
    R.I.P. Matt Eddy(SouthrnStyle) 11/26/2010
    May 2010
    39
    Quote Originally Posted by Mirror Detailing View Post
    +3..
    Super Member maddenbowler's Avatar
    Jun 2008
    203
    im not mike nor have any pictures but I did a touch up last week on my car. I wiped the area down with isoprophyl alcohol to remove all the oils and to get a good bond. Then after shaking the paint I dabbed the end of a toothpick in it and then slowly filled in the scratch. I would put some paint in, let it dry for a while and repeat. once the paint got a little higher than the original paint around it I began wetsanding. (2000 grit sandpaper soaked in water/car wash mix). I used back and forth motions with light pressure while constantly spraying the area with a soapy mixture.
    Once the paint was level I buffed with a porter cable, orange pad and meguiars m105.
    It turned it great.
    If I do another one I will take step by step pictures
    Mar 2010
    Ohio
    124
    My black car has little tiny chips all over the front. Those little white spots stick out like a sore thumb!
  1. Video: Paint polishing tutorial for beginners !!
    Last Post: 06-10-2018, 08:11 PM
  2. Paint Touch Up
    By Dmb5450 in forum Off-Topic
    Last Post: 05-01-2015, 06:53 PM
  3. touch up paint
    By alanguerin in forum Ask your detailing questions!
    Last Post: 07-09-2013, 05:08 PM
  4. removing spot gloss touch up paint to expose original paint?
    By slacknh in forum Auto Detailing 101
    Last Post: 09-16-2012, 11:37 AM
  5. A question about 3 stage paint and touch up paint.
    By Silverstone in forum Auto Detailing 101
    Last Post: 08-27-2010, 06:59 PM
