Results 1 to 9 of 9
    Newbie Member blue DX's Avatar
    Mar 2010
    help! question on waxing
    hi, newbie here. i washed and waxed my car the other day. i think i made a mistake in the waxing part. after applying the wax (just cleaner wax with some shine), i noticed that the roof had some splotches which that won't come off when it was time to buff up. i used a microfiber towel for buffing.
    do these splotches mean that i used to much wax that dried up? how can i remedy this?
    thanks!
    Super Member jpegs13's Avatar
    Oct 2009
    Manhasset, L.I. NY
    1,908
    Re: help! question on waxing
    Try spraying the blotches with a QD
    John
    Mean people suck
    Super Member Wax Gorilla's Avatar
    Jul 2009
    448
    Worst Case reprep the area and use a good quality Cleaner Wax and see if it removes the blotches.
    Super Member PAR Detailing's Avatar
    Oct 2009
    Louisville, KY
    894
    You might have applied it too thick, but then again maybe not. Which wax was it? Either way its nothing to be concerned about just spray a little QD (quick detailer) as jpegs said and it will come right off. Next time focus on applying it as thin as humanly possible and that should help prevent it
    "I can do all things through Christ who strengthens me"
    Jon Leidgen
    Super Member Shane731's Avatar
    Dec 2009
    Madison, AL
    3,498
    Seeing this is your first post, to Auto Geek!
    As the others have said, you can either go back over those spots with a quick detailer, or you can take some of that same cleaner wax, apply it to the blotchy areas, and then wipe it off while it's still wet. Won't affect your protection at all. Basically, it's using like product to remove like product, if that makes sense.
    Shane
    Welcome to Autogeek Online!
    Like dissolves like
    As someone else mentioned, gently reapply the same product to itself and work it over the affected area and then wipe it all off.
    What are you working on?
    Nov 2009
    112
    Or maybe clear coat failure and the wax filled in the effected area? Does your hood have any rough areas where the clear coat is damaged?
    Super Member ScottB's Avatar
    Mar 2006
    South Florida
    18,803
    quick detailers and more product indeed work well, just rebuff off immediately.
    Scott
    Mar 2010
    thanks for the replies and for the warm welcome!
    @mike.phillips: are you referring to what car i'm working on? it's an ae101 corolla sedan. white. car is quite old but not beat up.
    @trencher7: hmm i'm not sure if there is clearcoat damage already. but this is possible since for a time it had been parked under (though not directly) a tree. but it was enough to get sap on it.
    i might have put a little too much wax though... i'll try the "like dissolves like" technique first and see if it works. i have yet to buy QD.
  1. Question on machine waxing
    By CAD in forum Auto Detailing 101
    Last Post: 02-10-2013, 03:32 PM
  2. Waxing wheels question
    By spike in forum Auto Detailing 101
    Last Post: 11-15-2012, 04:41 PM
  3. I have a question about waxing.
    By sserdlihc in forum Ask your detailing questions!
    Last Post: 09-22-2011, 07:43 AM
  4. Sealant & waxing question
    By francoisk in forum Ask your detailing questions!
    Last Post: 06-17-2011, 09:12 AM
  5. Question about Klasse and waxing
    By vindicator in forum Auto Detailing 101
    Last Post: 10-03-2007, 03:57 PM
