Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 77
  1. #51
    Regular Member MobolWerks's Avatar
    Feb 2010
    Atlanta, GA
    168
    Re: Tell everyone one of your best detailing secrets!
    Quote Originally Posted by tommy grantham View Post
    .HARD WORK
    Whats are those white lines on your ragtop???
  2. #52
    Feb 2010
    Atlanta, GA
    168
    Maybe its the sweat from all your hard work
  3. #53
    Super Member Dubbin1's Avatar
    May 2009
    3,845
    If you have an open jar of peanut butter that's been used, usually you'll see some clear liquid pooling on the top of the peanut butter, this is vegetable oil,
    And all this time I thought it was peanut oil
  4. #54
    Super Member Rsurfer's Avatar
    Jan 2007
    14,110
    DLB
    I like your swirl remover.
  5. #55
    Super Member Da Fats's Avatar
    Aug 2009
    Chestertown, MD
    618
    8 once poli-seal + 1 once opti-seal= extra protection from poli-seal
    I use this to buff and seal all exterior glass and smooth plastic parts, it works phenominally to clean any and all stains on the plastic trim around windows/windshield, plastic mirror housing's ect ect...
    PB's trim restorer for all the textured plastic, buffed off after 30+ min soak time to bring back the trim...
    Try um... nothing beats em yet
  6. #56
    Super Member TLMitchell's Avatar
    Oct 2008
    NE Ohio
    1,341
    If I had a jar of peanut butter for every time I've posted the reason why peanut butter is used to remove polish and wax residue I would have a pantry full of peanut butter...
    The crunchy is tough to get out of nooks and crannies. Don't ask...
    I discovered by accident ONR makes bedliners look new. No matter how much I scrubbed or what APC I used bedliners still looked dingy. If someone's got to walk on 'em, especially in the rain, I don't want to dress them. I spilled some ONR mix on a tailgate liner and when I wiped it up I was amazed!
    One I've appropriated from a participant on another Forum, AA Tire Foam isn't so hot on tires, IMO. It works great on underhood pads, blackens 'em up and has some real nice cleaning properties.
    Around the house: since Johnson Wax discontinued Jubilee kitchen and appliance wax I've been looking for a replacement to no avail. UQW works primo... nice on mirrors and windows too.
    TL
  7. #57
    Mar 2010
    82
    If you have alot of baked on bugs or splatters on your front bumper or windshield, take a water soaked beach towel and lay it flat on the effected area 20 minutes prier to rinsing the car for a wash. The water will soak into the bug leavins and soften them up for quick and easy removal. I have been doing this for years to remove bugs from my motorcycle and plastic faceshields on my helmets.
  8. Likes SANTA3013 liked this post
  9. #58
    Super Member Nappers's Avatar
    Jun 2009
    Yreka, CA
    531
    Having my detailing products shipped to my work address and smuggle them home!
    Some good tips here though!
    UQW on windows....I used UQD but it made the windows streak a lot.
    I did use M205/polishing pad on glass with bad water spots that clay wouldn't touch and they turned out awesome.
    Aaron's the name!
    Live long and prosper Leonard Nimoy
  10. Thanks Craig Encinitas thanked for this post
    Likes Craig Encinitas liked this post
  11. #59
    Super Member O.C.Detailing's Avatar
    Jul 2009
    New Port Richey, FL
    740
    Here's a secret a TON of people will get good use out of.
    If you use the Meg's twins, 105/205, and you're having a hard time removing M105 from paint after polishing, put a couple of drops of M205 on your pad along WITH the 105 and polish. It makes the 105 MUCH easier to wipe off, reduces dusting a bit and gives 105 a longer work-time.
    Turtle-wax Bug and Tar remover on a microfiber towel has been the best bug-gut removal product I've used to this date, thanks to John (VR8) for both of these tips. They do work.
    yaatraphotography@gmail.com
    O.C.Detailing - New Port Richey, FL. - http://www.facebook.com/ocdetailingraleigh
    (434)851-1313
  12. #60
    The Peanut Butter trick is actually a trick that misses the mark...
    Somehow, somewhere, someway someone posted about using Peanut Butter to remove polish and wax residue and the post spread from there... it continues to this day.
    Here's the skinny...
    If you have an open jar of peanut butter that's been used, usually you'll see some clear liquid pooling on the top of the peanut butter, this is vegetable oil, it's the vegetable oil in the peanut butter that helps to break-up and dissolve polish and wax residue and also turn faded trim a darker color which will also act to mask the problem.
    Here's an old home-remedy for removing gum out of hair, which is a problem that sometimes happens to little kid, or how to get chewing gum out of carpet which is a problem usually caused by little kids, take and work some vegetable oil into the gum and it will act to dissolve it so instead of being a difficult, medium to remove it will break-up and then can be pulled out of or off of whatever it's stuck too...
    Shared on YouTube
  1. 20 detailing tips, tricks and secrets! (VIDEO)
    Last Post: 03-16-2020, 09:55 PM
  2. Share your best detailing secrets
    By raysanni in forum Off-Topic
    Last Post: 08-01-2014, 04:49 PM
  3. 4 secrets to grow your business
    By thebamboo23 in forum How to make money detailing cars
    Last Post: 06-24-2014, 06:54 AM
  4. $5 secrets
    By antti@561detailing in forum How to make money detailing cars
    Last Post: 01-17-2014, 11:03 PM
  5. What are your secrets??
    By jimmyjam in forum Auto Detailing 101
    Last Post: 02-17-2011, 09:39 PM
