Re: DoDo Juice Wax letdown?
If the container is large enough then there's another technique that enables you to take the wax down evenly instead of cone shaped.
The only paste waxes that I have used in the past have been the larger gold tins of M26 and the blue tins of M16, however I now also have a smaller 6oz. jar of XMT 180 that I have yet to try.
Aero, that is a classic video from when it came out. haha.
1.) Purple Haze is not a good wax. Despite what I've read about Purple Haze Pro's release, I believe Purple Haze is just not a good formula. It's not easy to work with and it's very streaky after buffing off.
2.) It needs manipulation to get it going. Press the applicator onto the wax pot and spin the pot around. You have to work it in the pot a bit to get it going. Also try exhaling deeply on the pot a few times, get the wax to warm up, which softens it up and makes it easier to work.
3.) Don't bother trying to apply by hand, you will just end up using way too much product. Only use a foam applicator pad - cotton and microfiber will absorb too much product and make it harder to spread.
Thanks for sharing the link to that video, I watched it and a couple of comments,
The foam finger pocket applicators are pretty cool and will enable you to more easily get the wax onto the foam exactly because they are smaller than most normal wax applicator pads.
Caution however when using these as the foam is thin and if you apply to much pressure you might instill Fingermarks.
This shouldn't be a problem with a finishing wax like the Dodo finishing waxes but it could be a problem if you use it with any type of compound or paint cleaner or maybe even a cleaner/wax.
I think the finger pocket applicators are ONLY for the wax stage.
As far as circular or straight line, if you watch closely, you can see PJ uses both methods. He starts out with the circle motion, moves to straight line for the edges, does some more circle motion then finishes with quite a few passes using straight line.
I see quite a lot of European's using straight line for it, so maybe its a cultural thing?
I've used them with both cleaner/waxes and paint cleaners for tight areas and thin panels like door jambs, wheels, etc.
I think that's what I said?
I wish AG carried the finger applicators.
I'm not sure if it's exactly like the one in the Dodo Juice video but we carry Foam Finger Pockets
Wolfgang Finger Pockets
Interesting, because when I asked Meghan, she said AG doesn't carry them. Ok, I asked specifically about the Dodo Juice ones but she didn't mention those ones.
Now I know
Now I know
They are on BOGO also, they are not good for waxing I think from what I remember when I used them a while back. They have a light cut to them.
Last Post: 12-28-2017, 06:25 PM
Last Post: 11-18-2011, 04:26 PM
Last Post: 10-14-2011, 04:20 PM
By outlander in forum Ask your detailing questions!
Last Post: 10-17-2009, 03:46 PM
By smokin' mark in forum Auto Detailing 101
Last Post: 04-25-2009, 06:53 PM
