Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Apr 2009
    113
    Advice needed:New Lake Country Hydrotech Pads
    I need to buy a set of 6.5" pads.
    Are the new LC Hydrotech pads a good 'substitute' for the CCS orange+white+black combo?
    I'll be using them with the Menzerna P203s and PO85rd on Honda paint.
    Thanks.
    Raoul
    Super Member Rsurfer's Avatar
    Jan 2007
    14,097
    Re: Advice needed:New Lake Country Hydrotech Pads
    Quote Originally Posted by jrt81 View Post
    Thanks.
    Raoul
    What machine do you have?
    Apr 2009
    113
    Hi there.
    I have a PC.
    Jan 2007
    14,097
    Hi there.
    I have a PC.
    If you have the older pc, then I would go with a 5.5" pad and get some 4" pads for heavier and tighter correction. The older pc doesn't have the power to spin 6.5" pads.
    Apr 2009
    113
    The 5.5"?
    Ok thanks for the advice.
    So, those 6.5" pads are mostly for the rotaries or flex?
    Jan 2007
    14,097
    The 5.5"?
    It's not so much the pad as it's the size. The new XP, Flex and new Griot should not have any problems spinning these 6.5" pads because of the increased OPM's and amp's.
    Apr 2009
    113
    So, if i stick with the 6.5", it will take me longer to do some corrections?
    Or will it be a futile attempt to do any corrections?
    Jan 2007
    14,097
    Once again, the 6.5" pads are too big and heavy to spin on the PC7424. It will work with the new PC7424XP which has more power.
    Apr 2009
    113
    Thanks for clarifying!
    Guess I better save up for the XP.
    I will give the 5.5" pads a thought.
  10. #10
    Mar 2006
    610
    I have to agree with the statements that the regular PC is better machine with the 5.5" pads. I have the original issue PC and always noticed that you could not put much pressure on the 6.5" pads or the pad would stop rotating. You could still do corrections, but it took a lot longer. I recently bought some 5.5" pads and a new 5" backing plate. Viola! I have much better performance with the PC. The PC is a fine machine and one of the pioneer mass selling random orbital polishers.
    I will buy the XP model when I replace my original PC. Until then, I will be using the 5.5" pad without any concerns as to using my machine. The Flex doe's have a forced rotation model that will not have this issue. I don't like the price of the Flex for one. I can buy a
    fine rotary polisher and a PC-XP for the price of the Flex. I also don't like the limited choice of backing plates and not having them readily
    available is another issue.
  1. Replies: 28
    Last Post: 02-26-2022, 08:11 AM
  2. Lake Country pads buying advice
    By cheekyage in forum Auto Detailing 101
    Last Post: 12-14-2016, 06:45 PM
  3. Lake Country Yellow CCS vs Cyan Hydrotech
    By dlc95 in forum Wool & Foam Buffing Pads
    Last Post: 09-26-2014, 10:03 PM
  4. Replies: 5
    Last Post: 08-22-2013, 11:10 AM
  5. Opinions Needed on Lake Country Beveled Edge 3.5 Inch Pad Pack
    By Deep Gloss Auto Salon in forum Auto Detailing 101
    Last Post: 11-12-2007, 02:09 PM
