Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Jun 2022
    Brown tires - can't fix
    Hey all - hoping someone has a good solution for this. I put new BFG KO2s on the wrangler back in August. After a month or so I started getting the browning on the tires. Not a big deal, I've dealt with it before on new tires. I started with just dawn soap and water and a tire brush as that has normally worked. No luck, actually I think it made it worse. Ok I thought, time to go to the tire cleaners. I went through Mother's, Armor all, and Turtle wax bottles of tire cleaners with no luck. At this point the tires had been washed 5-6 times and I've used 5 bottles of cleaner with no results. I gave up and put a light coating of VRT to get them black again. Looked good, figured maybe the gases would work themselves out. Since that episode, the browning has come back about every few months as the VRT has worn off. I've reapplied the VRT a couple times, but now they are browning again.
    Shouldn't the browning and gassing process be done now? What else am I supposed to use to fix this?
    Nov 2015
    Los Angeles, California
    13,806
    Re: Brown tires - can't fix
    You mentioned Mothers. Did you use this specific Mothers tire cleaner?
    Super Member evo77's Avatar
    Mar 2008
    582
    If your tire is STILL brown after thorough scrubbing and cleaning, then its not because its dirty. The rubber compound and conditioners in your specific tires are just formulated in such a way that they are causing a more brown-ish appearance.
    Unfortunately there isn't anything you can do about it.
    The best you can hope for is that if you continue with a regular maintenance of cleaning the tires with a quality tire cleaner (NOT dish soap!!!) and maybe, just maybe in time the brown color becomes less brown.
  4. Likes DFB, Prange liked this post
  5. #4
    Jun 2022
    Yep that's the one
  6. #5
    Nov 2015
    13,806
    Quote Originally Posted by Hawk75 View Post
    Yep that's the one
    What brush are you using to scrub?
    IME especially when tires are new you sometimes really have to go at them to get that initial film off them. If you have a Tuff Shine Tire Brush or similar they tend to work best at it.
    Spray the tire, scrub, spray again, scrub then rinse. Or if it was me I’d go 3 rounds of spray & scrub before rinsing once and repeat at least twice. After the 3rd time of scrubbing and rinsing you should hopefully start seeing the rubber turn a deep clean black.
    Sometimes you’ll literally see that brown film peeling off as you’re scrubbing it with that Mothers tire cleaner. If that somehow doesn’t work Stoners Tarminator would be my next bullet, but the Mothers should work better leaving the tires properly clean & black.
  7. #6
    Super Member Bill D's Avatar
    Mar 2006
    The First Coast of FL
    2,391
    Tuff Shine tire cleaner got the film off my new tires and left their white walls nice and bright. Set aside plenty of time for scrubbing.
  8. #7
    Jun 2022
    Using the tuff shine tire brush. Went 1 round with the Mothers before I ran out. Switched to the Turtle Wax Hybrid solutions tire cleaner, 2 bottles and did 2 rounds on each tire. Crazy but if there was any improvement it was minimal. Had some basic TW tire cleaner in garage so tried that as well. That's when I gave up and put on the VRT. Supposed to be nice this weekend here in Iowa so maybe I'll give it a go again. frustrating
  9. #8
    Jun 2022
    Quote Originally Posted by Bill D View Post
    Thanks. Haven't seen that in the local stores, I'll look online to order.
  10. #9
    Super Member Rsurfer's Avatar
    Jan 2007
    14,100
    Get a tire brush that fits a drill. Will save you a lot of time and energy. If using Tuff Shine..scrub till the foam is white and not brown.
  11. #10
    Nov 2015
    13,806
    This sucks. I feel for you. You went and bought the tires you wanted and so far this has happened. Well if the so called proper cleaners can’t get results, maybe it’s time to test the hard stuff. LA’s Totally Awesome, straight undiluted.
    They say Dura Shine Tire Cleaner that comes with their tire coating kit works amazing. I’ve never tried it though.
  1. Cleaning brown tires
    By Dadillac in forum Ask your detailing questions!
    Last Post: 10-08-2023, 12:20 AM
  2. Brown tires?
    By RLucky82 in forum Ask your detailing questions!
    Last Post: 10-29-2017, 12:11 PM
  3. Very brown tires help :-(
    By Redfireshaker06 in forum Auto Detailing 101
    Last Post: 12-18-2016, 04:54 PM
  4. Can't Get Rid Of Brown Tires!
    By Whiplash Willy in forum Auto Detailing 101
    Last Post: 12-11-2013, 09:16 PM
  5. Tires still brown after scrubbing...
    By rockford33 in forum Auto Detailing 101
    Last Post: 09-12-2011, 10:07 PM
Members who have read this thread: 51
