Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Jun 2015
    35
    What are these little red spots on my car?
    Washing my cars today I noticed these reddish spots (not rail dust) all over my white Sti as well as my silver 4Runner.
    The Sti is ceramic coated. Washing the car did not remove all of these. I did use a quick detailer and that seemed to remove most of these.
    Curious what these spots are and the best way to remove them without damaging the ceramic coating.
    Assuming these are from bugs, but not certain.
    Attached Thumbnails Attached Thumbnails What are these little red spots on my car?-img_8429-jpg   What are these little red spots on my car?-img_8430-jpg
    Super Member DFB's Avatar
    Aug 2019
    Australia
    3,169
    Re: What are these little red spots on my car?
    Quote Originally Posted by Temple90 View Post
    It will be either iron contamination, water spots or possibly road tar. I have witnessed something similar, which was caused by high iron content water spots.
    Start with an iron remover, this will be safe on your ceramic coating. Inspect.
    If it remains, try a tar remover on an isolated spot, rinse and inspect.
    From there, try a water spot remover. Inspect.
    If all those fail to remove the issue, you will need to try mechanical efforts. Start with a clay bar or towel, then progress to polishing if needed, which would give the coating a rattle or remove it entirely. In this case, you could try using Carpro Essence+ or Rupes Uno-Advanced, which is a non-abrasive (Essence+) or lower abrasive polish (Uno Adv) for ceramic coatings.
    Good luck.
    CARPRO Essence PLUS
    RUPES UNO Advanced
    Jun 2015
    35
    Quote Originally Posted by DFB View Post
    Good luck.
    CARPRO Essence PLUS
    RUPES UNO Advanced
    I can remove the spots with a quick detailer which makes me think they are bugs or similar. Never heard of high iron content water spots. How do they get on a car and any way to prevent?
    Oct 2011
    92
    If you can remove them with a quick detailer why can’t the normal wash remove them?
    Good luck.
    CARPRO Essence PLUS
    RUPES UNO Advanced
    I’m not sure Essence + is a “polish”?
    Regular Member Sleper's Avatar
    Mar 2006
    120
    Sounds like fallout or brake dust. spots start out black and then turn to red or orange before being removed. you can also use a clay bar to remove them. With a good coat of wax they stick less and remove much easier. much more noticeable on white but can be seen on darker colors and can easily be felt by running your hand over the paint. Good luck
    Aug 2010
    New Jersey
    15,170
    Those could easily be some kind of sap or tree gunk.
  7. Likes DFB liked this post
  8. #7
    Mar 2011
    PA
    5,792
    Road tar or tree sap would be my guess. Park near any trees?
    2018 Colorado ZR2
  9. Likes DFB liked this post
  10. #8
    Aug 2019
    Australia
    3,169
    Quote Originally Posted by vaced View Post
    Correct, I probably should have wrote that differently, hence the phrase "non abrasive".
    In any case, I don't think the OP would need to use it, as many have highlighted, a likely outcome is some sort of sap, tar or iron fallout.
  11. #9
    Aug 2019
    Australia
    3,169
    In that case, the owner of the car parked on her lawn, the sprinklers came on overnight and showered the car in water, water that is drawn from an underground bore high in iron. I tried all possible chemical options but ended up polishing it out and recoating the car.
  12. #10
    Nov 2015
    You guys are going to laugh at me when I say this - But I will take my chances. My father in law had a very similar issue with his vehicles when he purchased new mulch and there was some sort of spore or mold associated with that type of mulch. If I am not mistaken it was called Artillery Fungus.
  13. Thanks KirkH thanked for this post
    Likes KirkH liked this post
  1. Replies: 20
    Last Post: 09-20-2017, 04:24 PM
  2. What exactly are these spots?
    By carguy2007 in forum Ask your detailing questions!
    Last Post: 09-19-2017, 09:08 PM
  3. What are these spots?
    By 11Silverado in forum Auto Detailing 101
    Last Post: 04-20-2015, 10:26 AM
  4. Can someone tell me what these spots are?
    By buffguy in forum Ask your detailing questions!
    Last Post: 02-01-2013, 12:02 AM
  5. spots all over the car
    By 99tl in forum Auto Detailing 101
    Last Post: 07-10-2009, 02:02 PM
Members who have read this thread: 43
