Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Aug 2013
    St Louis metro (Illinois)
    5,811
    Re: Tough removal of Sonax EX 04-06 - fun turned frustrating
    Quote Originally Posted by Lance Mark View Post
    I've had some product sit a bit too long after i polished, or I used too much or too little....not sure, but generally, after a correction step, one swipe of a microfiber pulls up the lion's share of the spent product on the paint
    every once in a while, it doesn't cooperate....I usually don't try to buff it too much at this point if I can avoid it
    rather than work the surface with the MF to get it off, I'll usually do a quick sprits of prep, and it cleans up slick and quick
    I've experienced something similar. Before I started using coatings and had a panel prep on hand, a spritz of QD spray would help remove and stubborn polish remnants.
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    That green pad, wether it be the Hex Logic of the Buff and Shine is my most used pad for starting paint corrections. And that machine is my most used tool.
    A lot of times when I have issues removing polish it's from generating to much heat via pressure, and tool speed. That being said I've never tried that particular polish.
    That pad with Ultimate Compound was the majority of what I used for heavy cutting situations when I started using the PC in 2013 (I bought it in 2011, but was still mostly using the rotary). I've read that Meguiar's adds certain cleaners that help cut through the road grime and water spots in the formula. These ingredients could help cut through previously applied protection, which could also be a culprit in difficult wipe off.
    I did a car for a co-worker. I started it at the shop, but had to finish it at home. In the interim I applied Optimum Car Wax to protect it for the week until I could get to it. Big mistake. On this car I started with 3D ONE on a Buff and Shine Uro-Fiber, and on the outside perimeter of the work area therer was a build up that didn't want to wipe off. So I did a panel wipe with Optimum Power Clean to remove the wax, and a "rinse" with ONR in a spray bottle. This took care of that situation.
  3. #13
    Newbie Member WorldMattyBlue's Avatar
    Nov 2016
    Boston
    Thanks all! I did a few more tests, and also bought some new goodies, including the Hercules forced rotation DA.
    I put a new backing plate on the PC, broke out the Sonax and a green pad, and tested on my wife’s VW Atlas. All the same equipment and prep as with my car.
    Experience was pretty different and results were good. Aside from just being another car, another color…it did not have any Beadmaker on it for at least a couple months.
    So I’m thinking there was still some Beadmaker on the paint, and the Megs UC had enough cut to get through. The Sonax didn’t have enough cut, and was being pushed around with some Beadmaker.
    It does make sense, and I’m going to say that was the issue so I can stop thinking about it.
    Next up, test out the new DA!!
    2014 BMW 535 M Sport
  1. Sonax BSD and Turle Wax Ice Seal and Shine Removal?
    By soapboxpreacher in forum Auto Detailing 101
    Last Post: 10-23-2019, 04:18 AM
  2. Most frustrating day ever! HELP!
    By Venomv8 in forum Auto Detailing 101
    Last Post: 04-18-2017, 04:53 PM
  3. Replies: 1
    Last Post: 09-04-2013, 02:04 PM
  4. Frustrating spots on paint
    By mrj7500 in forum Auto Detailing 101
    Last Post: 06-22-2011, 11:54 PM
  5. frustrating offering
    By FLMike in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 05-25-2006, 02:06 PM
