Results 1 to 7 of 7
    Super Member chilly's Avatar
    May 2006
    Alaska
    1,775
    Best Quality OEM or Aftermarket Touch up Paint
    I have some fine rock chips I need to deal with
    Do you pros have any preference on brands of touch up paint?
    I am not talking about "complete systems" like Dr Colorchip or Langka with all the leveling fluids and stuff
    Just a best quality touch up paint
    Thanks in advance
    Jan 2015
    Simi Valley, CA
    1,783
    Re: Best Quality OEM or Aftermarket Touch up Paint
    Most paints specifically marketed as touch-up paint are acrylic lacquer. While lacquer has its benefits, primarily it is the fastest drying of paint types, that fast drying nature is also a curse. You have very little flow time to work with. The paint starts to set-up very quickly and it's hard to get it to flow within the chip.
    Acrylic enamel or urethane (with the appropriate hardener) is my preference for single stage repairs where you do not intend to follow with a clear, or for the color coat when you will follow with clear. Water borne base coats also work well when you are following with a clear. Any of these will flow much better than lacquer and give you more working time. Plus, if you are not happy with the application, they are very easy to remove and start over.
    For the clear coat my preference is a two-component urethane.
    It really boils down to your expectations. If you just want to get some color in the chip so it doesn't stand out from 10 feet away, then the traditional touch-up lacquers will do. But if you want a repair that is harder to detect, even under closer inspection, that is harder to achieve with traditional lacquer-type touch up paints.
  3. Thanks chilly thanked for this post
    Likes PaulMys, chilly liked this post
  4. #3
    Aug 2013
    St Louis metro (Illinois)
    5,809
    Which color match the best? I've always gone with OEM to avoid any issues with an aftermarket product not looking quite right.
  5. Thanks chilly thanked for this post
    Likes chilly liked this post
  6. #4
    Super Member VISITOR's Avatar
    May 2007
    9,729
    i am the jump starter.
  7. #5
    Jan 2015
    Simi Valley, CA
    1,783
    Generally speaking, there is no such thing as OEM touch-up paint. The paint you buy from the dealer is supplied to the OEM by a paint supplier such as PPG, Axalta, Glasurit, etc. These same paint suppliers also provide the paints used at the factory during original manufacturing.
    So, whether you buy the touch-up paint from the dealer or another paint supplier, your chances at an acceptable color match are about the same.
  8. Thanks chilly, Desertnate thanked for this post
  9. #6
    May 2006
    Alaska
    1,775
    Thanks guys, lots of good feedback
    It gives me a good start to study up on the subject
  10. #7
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,226
    Quote Originally Posted by chilly View Post
    Thanks in advance
    Ive used paint from automotivetouchup.com couple times. Everytime had been a perfect color code match for my silver birch color. Used the rattle cans, base and clear.
  11. Thanks chilly thanked for this post
    Likes chilly, Vegas1 liked this post
  1. Removing Aftermarket Paint Job
    By TheMikeskies in forum Auto Detailing 101
    Last Post: 10-02-2019, 06:43 PM
  2. High quality Touch up paint recommendations
    By bmwstephen in forum Auto Detailing 101
    Last Post: 04-24-2015, 03:58 PM
  3. Replies: 12
    Last Post: 07-05-2013, 04:18 PM
  4. Paint Quality?
    By NYCLR3 in forum Auto Detailing 101
    Last Post: 10-14-2011, 07:26 PM
  5. Aftermarket Paint
    By phrosyn in forum Auto Detailing 101
    Last Post: 06-29-2009, 03:13 AM
