Results 1 to 5 of 5
    May 2023
    Safe nitrocellulose solvent for clear coat and paint
    I sprayed large area too thinly with a "Removeable spray coating" meant for cars. The instruction says to use nitrocellulose solvent to remove it - what would be a safe nitrocellulose solvent for my Honda Accord 2019 to not damage the clear coat and paint?
    Jan 2015
    Simi Valley, CA
    1,783
    Re: Safe nitrocellulose solvent for clear coat and paint
    Nitrocellulose is a type of lacquer paint used in early automotive finishes. Not sure of the exact years it was used, but when I started painting in the 1960s, it had already been replaced by acrylic lacquers.
    I would think any modern lacquer thinner would work for you. Acetone would also work but it dries faster than most lacquer thinners so working with the lacquer thinner may be a better option in your case. Either of those solvents do pose some risk to existing finishes so be careful. Avoid excessive dwell times. Dwell only as long as necessary. And definitely try a small spot before going crazy with it.
    A safer alternative would be mineral spirits although it may not dissolve what you're trying to remove. It's worth a try though. That would be my first choice before moving on to the more aggressive lacquer thinner or acetone.
    Another option, depending on the thickness of what your trying to remove would be to go at it with a polisher and compound.
    Good luck.
  3. Likes PaulMys liked this post
  4. #3
    May 2023
    Re mineral spirits, could you recommend a product that I could buy online with a description how to use it safely?
  5. #4
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Quote Originally Posted by 2black1s View Post
    Good luck.
    John, what is your opinion on 3M General Purpose Adhesive Remover for this? Would that work?
    I know that it is clear coat safe, and I have seen it remove things that acetone would not. But I'm not sure how effective it would be in this case.
  6. #5
    Jan 2015
    Simi Valley, CA
    1,783
    It's worth a try.
  7. Likes PaulMys liked this post
  1. Replies: 27
    Last Post: 03-24-2023, 10:46 AM
  2. Replies: 13
    Last Post: 01-26-2015, 09:53 AM
  3. clear coat and paint safe adhesives?
    By Texarkana in forum Auto Detailing 101
    Last Post: 10-25-2014, 12:49 PM
  4. Nitrocellulose paint care
    By Rastaral39 in forum Ask your detailing questions!
    Last Post: 06-26-2014, 07:13 AM
  5. Pinnacle Clear Coat Safe Wheel Cleaner
    By SYMAWD in forum Product Reviews
    Last Post: 04-21-2014, 07:45 PM
Members who have read this thread: 7
