Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Super Member SNP209's Avatar
    Sep 2016
    742
    Re: If you need more cut, which do you find is better to go with a more aggressive compound or pad?
    Apex detail did a video a while ago on this topic, really makes you go hmmm...
  2. Likes chilly liked this post
  3. #12
    Super Member chilly's Avatar
    May 2006
    Alaska
    1,900
    Quote Originally Posted by SNP209 View Post
    I remember this was a real eye opener when it first came out and it is one of those lessons that’s super important (at least to me) but easy to forget when you get caught up in the “gotta have it” moment and you get lost in a sea of too many choices
  4. Likes dlc95 liked this post
  5. #13
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,020
    I try and start with a polish and change the pad.
    For instance, say I start with Ultimate Polish on a blue Hex pad. If that doesn't do the job, I'll switch to green. If that doesn't work I'll move to a fiber pad.
    That doesn't work, I'll go back to green with Ultimate Compound, and to a fiber pad afte that if necessary.
    Seems a little convoluted, but those are my pathways.
  6. Likes Paul A., chilly liked this post
  7. #14
    May 2006
    Alaska
    1,900
    There is nothing convoluted about your methodology at all
    Unless paint is absolutely trashed I will almost always start with a polish and work backwards just changing pads, even if I KNOW it won’t work, because there have been times that I KNEW it wouldn’t work, but it did, and I had no need for bigger guns
    We are taught to use a pad, product, and process best calculated to achieve the desired results, but starting on the gentle end of the calculated spectrum and possibly needing more is the safest way to go in my book and learning your liquids intimately and adjusting pads to suit the situation is a skill worth developing
  8. Likes dlc95 liked this post
  9. #15
    May 2013
    Rochester Hills, Mi
    6,020
    Quote Originally Posted by chilly View Post
    Thank you, Chilly!
    I have always liked the idea of having "headroom". Knowing that if the polish / polish pad combo isn't sufficient, there are options in either direction.
    The reason I do that is to try and make it a "one step" process.
    Ultimate Polish, M205, Menz 2500, Jescar Medium, 3D ACA520 / ONE, Optimum Hyper Polish.
    They've all done more than I could have expeced. There were times like you, I "knew they wouldn't work", but I was wrong. Often they finished really well too.
  10. Thanks chilly thanked for this post
  11. #16
    Aug 2020
    923
    If it looks bad, an orange cutting pad is a good place to start. Now, I've had stuff that the orange cutting pad wouldn't remove but moving to a Griots fast finishing MF pad took out.
  12. Likes chilly liked this post
  1. More aggressive pad? Or more aggressive compound?
    By tone357 in forum Auto Detailing 101
    Last Post: 12-28-2015, 10:17 PM
  2. More aggressive compound or pad?
    By Ztandem in forum Wolfgang Car Care
    Last Post: 12-26-2015, 01:33 AM
  3. Replies: 4
    Last Post: 08-02-2013, 08:28 PM
  4. POLL: More Aggressive Compound OR Pad?
    By waldron80 in forum Auto Detailing 101
    Last Post: 03-26-2008, 05:15 PM
  5. Replies: 0
    Last Post: 06-01-2006, 01:21 PM
Members who have read this thread: 6
