Results 1 to 7 of 7
    May 2023
    52
    How much more cut do you get when going from an 8mm to a 15mm throw dual action polisher?
    I understand it might be hard to quantify but if using an 8mm dual action polisher with a pad that has a cut of 5 out of 8. Would you say that a 15mm throw dual action polisher would give a cut of 6, 7 or even an 8 out of 8 with the same pad? I'm trying to get a better understanding on how much the throw changes the aggressiveness of a particular pad.
    Nov 2015
    Los Angeles, California
    13,765
    Re: How much more cut do you get when going from an 8mm to a 15mm throw dual action polisher?
    One could say that since the orbit goes from standard 8mm to 15mm you could expect almost twice as much cutting power all things being optimal [pressure, arm speed, washer mod]
    I’ve known people who’ve encountered situations where an 8mm polisher simply couldn’t fully correct paint but once they pulled out the 21mm it handled it with ease.
  3. Likes Bri26 liked this post
  4. #3
    Super Member Danube's Avatar
    Jan 2012
    Australia
    1,185
    If this is the case, then 8mm throw Flex 3401 would be far inferior to any 15 or 21mm machine.
    Flex 3401 & PE14
  5. #4
    Super Member VISITOR's Avatar
    May 2007
    9,729
    Quote Originally Posted by Danube View Post
    If this is the case, then 8mm throw Flex 3401 offers would be far inferior to any 15 or 21mm machine.
    if you have a long throw DA (15mm/21mm) and flex 3401 vrg side by side on panel where there are curves, the long throw could slow/stop rotating where as the flex would keep spinning (since it's gear driven) many times over and do more work. sometimes there are variables...
    i am the jump starter.
  6. #5
    Dec 2018
    7,177
    For cars I believe Mike Phillips prefers the Flex 3401 because it’s gear driven and will not stop. Best tool for speed.
    A long throw will cover more ground so would be faster than non gear driven 8mm polisher.
    On big trucks and vans (flat panels) a long through would probably be faster than a gear driven.
  7. #6
    Super Member SNP209's Avatar
    Sep 2016
    728
    This video demonstrates the more aggressive action of long throw polishers and talks about how they have different needs when it comes to pad design
  8. #7
    Sep 2016
    728
    This is where forced rotation really shines because you can really "dig in" and not worry about pad stall. Everyone talks about keeping the pad flat but in certain situations you have to tilt the polisher to really engage the pad and remove defects. This can be done with a long throw, but the chance of stalling is always there.
    Joe Metlow demonstrates this technique with a long throw in this video
  9. Likes opie liked this post
  1. What's your go to dual action polisher pad?
    By Bri26 in forum Ask your detailing questions!
    Last Post: 08-09-2023, 04:20 PM
  2. Griot's BOSS G10 Pneumatic Polisher - Air powered 10mm dual action polisher!
    Last Post: 04-08-2018, 09:52 PM
  3. Detailing Class - RUPES Cyclo 15mm Free Spinning Dual Head Orbital Polisher
    Last Post: 04-06-2018, 02:39 PM
  4. Replies: 9
    Last Post: 10-03-2014, 09:06 PM
  5. Dual Action Polisher
    By sebastian12 in forum Auto Detailing 101
    Last Post: 03-21-2011, 06:47 PM
