Results 1 to 8 of 8
    Junior Member PM5C's Avatar
    Sep 2019
    Scottsdale AZ
    80
    How to restore leather on steering wheel
    Anyone have success restoring a worn section on a leather steering wheel? Car’s eight years old, so not unusual to see but I’d be interested in knowing if there’s a way to match the original color and texture without it being an obvious fix.
    How to restore leather on steering wheel-img_4318-jpg
    Attached Thumbnails Attached Thumbnails How to restore leather on steering wheel-img_4318-jpeg
    Super Member DFB's Avatar
    Aug 2019
    Australia
    3,174
    Re: How to restore leather on steering wheel
    Quote Originally Posted by PM5C View Post
    Have a look into ColourLock, they offer a range of repair products for that sort of wear that are reasonably easy to use. You can also select products to suit your particular vehicle, especially good when you are needing to re-dye sections.
    May 2023
    52
    First thing I would do is wipe it down with a microfiber cloth dampened with water. I had similar areas on my leather steering wheel that initially looked like wear spots but turned out to be just some grime that wiped off.
  4. Likes DFB liked this post
  5. #4
    Aug 2019
    Australia
    3,174
    Quote Originally Posted by Bri26 View Post
    Good suggestion.
    I once cleaned a car with similar looking steering wheel and gear shifter. It ended up being makeup residue.
  6. #5
    Super Member Danube's Avatar
    Jan 2012
    Australia
    1,185
    Yes, it needs cleaning however it looks like the dye is gone.
    Letherique has a kit specifically made for that.
    Flex 3401 & PE14
  7. Likes Jackismydog liked this post
  8. #6
    Jan 2012
    Australia
    1,185
    How to restore leather on steering wheel-ll-jpg
    Flex 3401 & PE14
  9. Likes Eldorado2k liked this post
  10. #7
    Aug 2020
    916
    You could try spraying ColorBond on the steering wheel.
  11. #8
    May 2007
    671
    If this car was a keeper, I would probably just err on buying a new steering wheel
    It's worn smooth from use
    The upholstery guys - if they were doing it, they would sand it even further and respray. They sand in order to get *grit* so that the spray has places to bite into.
    Since it literally is in the periphery of the eye, that would drive me *autopian OCD nuts*
    I suppose you could dry a DIY sand (to get back texture) and redye to see if the results are acceptable as a 1st pass
  12. Likes DUBL0WS6 liked this post
  1. Leather dye for steering wheel?
    By brettS4 in forum Auto Detailing 101
    Last Post: 07-01-2017, 03:40 PM
  2. Help! Steering wheel leather
    By waterloomarc in forum Auto Detailing 101
    Last Post: 01-08-2013, 12:00 PM
  3. Leather Steering wheel
    By Twister in forum Auto Detailing 101
    Last Post: 07-19-2011, 10:26 AM
  4. Leather steering wheel
    By IOMCAMARO in forum Auto Detailing 101
    Last Post: 11-30-2010, 12:43 AM
  5. Leather steering wheel
    By bodavenport in forum Auto Detailing 101
    Last Post: 10-30-2010, 08:00 PM
