Results 1 to 10 of 10
    Apr 2019
    193
    GYEON Quartz Silk Dryer microfiber
    it was put in the dryer. is it ruined? safe to use?
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Re: GYEON Quartz Silk Dryer microfiber
    What are you asking, exactly?
    Did it melt the fibers?
    Was it dried with a dryer sheet?
    Apr 2019
    193
    I assume to test if the fibers melted is just seeing if it is still smooth? What is the significance of a dryer sheet?
    Jan 2014
    Eastern L.I. NY
    10,773
    Quote Originally Posted by tim500 View Post
    There are two schools of thought on drying MF towels.
    One is that dryer heat will cause irreparable damage to the towel.
    The other (which I believe), is that dryer heat cannot get hot enough to damage the towel.
    Dryer sheets impart a lanolin-like waxy substance onto the items in the dryer. Not good at all for any MF towel.
    Super Member Danube's Avatar
    Jan 2012
    Australia
    1,185
    The M/F towel should be fine.
    Flex 3401 & PE14
    Dec 2018
    7,179
    I dry mine all the time…. Your good. As Paul stated though a dryer sheet could coat the towel an make it less absorbent.
    If it was, soak it in An APC or better yet buy P&S Rags to riches. Soak over night. Wash on hot (it will be fine) and then dry and your good.
    I like to dry my towels on low for 15 mins then hange dry.
    Aug 2020
    914
    I could see high heat for a long cycle maybe being an issue. Low heat settings, I can't see being a problem.
    Mar 2011
    PA
    5,793
    LOW HEAT or air dry.
    2018 Colorado ZR2
  9. Likes Coatingsarecrack liked this post
  10. #9
    Junior Member Game's Avatar
    Jun 2013
    78
    Are drying towels supposed to be air dried?
    I’ve always used low heat without issue.
  11. #10
    Nov 2015
    Los Angeles, California
    13,765
    Quote Originally Posted by Game View Post
    Low heat in the dryer is fine
  1. How To: GYEON quartz Q˛ Trim
    By Jeff at Gyeon in forum GYEON Car Care Products
    Last Post: 02-01-2019, 12:24 PM
  2. Gyeon silk drying towel and rinseless washes.
    By JDGolden in forum Auto Detailing 101
    Last Post: 06-19-2018, 07:23 AM
  3. Best way to use Gyeon Silk Towel
    By cheekyage in forum Auto Detailing 101
    Last Post: 06-03-2018, 10:20 AM
  4. How To: Protect Your Wheels with GYEON quartz Q2 Rim
    Last Post: 03-08-2018, 01:00 PM
  5. Is Gyeon Skin available on Dark Web-silk road.
    By Mgavin1985 in forum Auto Detailing 101
    Last Post: 03-05-2018, 09:22 PM
