Results 1 to 5 of 5
    Super Member Lance Mark's Avatar
    Mar 2021
    357
    please help me understand the difference between a wet and dry foam
    I have an iK FOAM Pro 2 which came with three different nozzles, a wet nozzle, a dry nozzle, and an intermediate nozzle
    I plan on using to apply CARPRO's Lift
    is LIft a wet foam? what is the difference
    Sep 2015
    2,174
    Re: please help me understand the difference between a wet and dry foam
    Quote Originally Posted by Lance Mark View Post
    the soap does not determine the type of foam...wet or dry....the nozzle that you use in the IK foamer does. I've used the nozzle that produces the wet foam.....and liked that so I did not try the others. If you're using Lift as a pre-soak.....I'm gonna recommend Bilt Hamber Touchless or Bilt Hamber Auto Foam in that role. I use Touchless and have found it to be more effective than Lift.
  3. Likes DanaDetailingPros liked this post
  4. #3
    Mar 2021
    357
    Quote Originally Posted by briarpatch View Post
    i'll try it next, thanks for the tip and the info
  5. #4
    Dec 2018
    7,235
    Yeah I like the medium tip but wet would be good too. For a presoak your not looking for shaving cream thick.
  6. Thanks Lance Mark thanked for this post
  7. #5
    Super Member DFB's Avatar
    Aug 2019
    Australia
    3,298
    I have always thought of wet foam as being thinner and runnier.
    Dry foam would be like shaving cream type, being thicker and heavier.
    In the case of the iK foamer, then the selected nozzle will play a role in what type of foam generated. However, some soaps are naturally thicker, some naturally runnier. For example, I find P&S Pearl and Optimum Car Shampoo to be thinner and runnier. Carpro Reset, Gyeon Bathe and Adams Mega Foam produce a thicker, heavier foam.
  8. Thanks Lance Mark thanked for this post
  1. Replies: 6
    Last Post: 06-08-2018, 10:49 AM
  2. Tornador Black VS Tornador Foam Gun. What is the difference?
    By CarbonDetailing in forum Auto Detailing 101
    Last Post: 02-08-2018, 12:19 PM
  3. Replies: 11
    Last Post: 05-05-2017, 11:39 AM
  4. Difference between Durafoam & European Foam Edge Pads
    By doctordon in forum Auto Detailing Tools and Accessories
    Last Post: 02-09-2011, 07:46 AM
  5. Do Not Understand
    By Largebore in forum Auto Detailing 101
    Last Post: 07-24-2007, 12:34 PM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
