Removing stains from asphalt driveway
My tire/wheel cleaning products leave that dreaded "eyebrow" on my asphalt driveway. Any recommendations on removing without causing damage to the driveway?
Re: Removing stains from asphalt driveway
Originally Posted by
rwa757
Scrub with and apc and pressure wash
rwa757
Is it the cleaning products or the tire dressing? I've seen the 'eyebrows' on asphalt after using an aerosol dressing......I solved that problem by pulling the vehicle onto pieces of cardboard, if that helps you at all
From my experience the "eyebrow", if I'm imagining it right, is actually the grime and brake dust that collects around the edges of the tires while you're washing. The water will eventually runs off, but the solids are left behind.
Are the "eyebrows" a stubborn and hard to remove? My driveway is graded such that water runs off pretty easily. Instead of "eyebrows" I just get lines or streaks that follow the run-off path, but I can rinse them off pretty easily right after I wash my car.
Something else to think about is the possibility of sealing the driveway with a clear concrete sealer. It would keep the grime from getting as embedded in the texture of the concrete and make it easier to clean off.
I've actually heard laundry detergent works really well for safe cleaning of oil and such from pavement, could give that a shot? Since you say asphalt driveway I'd start gentle and work up for fear of compromising the surface.
VISITOR
i use toilet bowl cleaner gel with bleach on the driveway to help reduce and get rid of some oil stains left behind. i applied it and left for a few hours, then took a tire brush and scrubbed as much as i could, and then blasted it with the finest pressure washer nozzle. it took a few times but it worked well...
Did you try a drill brush?
noorth
no, just a tire brush. the oil stains were not very big...
it's the cleaning product. The tire dressing is not a spray on product.
Thanks Briarpatch, it's the cleaning product/residue. The dressing I use is applied with a foam applicator.
