Results 11 to 20 of 24
    Nov 2015
    Los Angeles, California
    13,791
    Re: Request: Advice on removing road acquired spots off of ceramic/PPF
    Quote Originally Posted by snovvman View Post
    I tried heat too, nothing.
    What do you mean you tried heat?
    If they’re not visible to the naked eye, I wouldn’t worry about it.
  2. Likes Tasmania, opie, 392hemi liked this post
  3. #12
    Super Member Tasmania's Avatar
    Jan 2017
    Tasmania, Australia
    911
    I thought the PPF was damaged so i suggested heat i didn't know you could only see the spots with a ultraviolet light
    I thought UV as in the sun etc
  4. #13
    Jan 2017
    Tasmania, Australia
    911
    It's probably the slip solution they used when putting on the PPF forget about it it's fine
  5. #14
    Dec 2018
    7,205
    Whatever it was etched/stained your coating. As you found out, whatever would have chemically removed it would remove the coating.
    As Guz said Would polish and recoat.
  6. #15
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,230
    Only visable under UV light.....Maybe 2 ppl were doing some procreating against your car and made a mess? Request: Advice on removing road acquired spots off of ceramic/PPFRequest: Advice on removing road acquired spots off of ceramic/PPFRequest: Advice on removing road acquired spots off of ceramic/PPF
    Seriously though, personally i wouldnt worry about it. But if ya are id try what guz said.
  7. Likes The Guz liked this post
  8. #16
    Apr 2014
    Quote Originally Posted by Tasmania View Post
    I'm pretty sure it's not the slip solution because after the PPF and coating, I went through the car with UV and they were not there. Also, they originated from the surface--visible to the eye. After cleaning what looked like bird dropping or some sort of fallout, I used UV to see if the cleaning had any effect on the coating. That was when I discovered them.
    My concern is that if they were able to etch into the coating, I want to prevent them from further etching down into the PPF.
    What would be the advantage of polish versus chemical removal, since they both remove coating? To me, chemical can be more surgical in that it only removes the coating and contaminant. Polishing may take more off the the surface?
    Quote Originally Posted by opie View Post
    Or some weirdo on his own...
    Anyway... I just want to prevent any deeper etching.
    Curiously, why is everyone suggesting the mechanical removal method (i.e., polishing) rather than the chemical method (Goof Off) when both work?
  9. #17
    Aug 2022
    Dana Point CA
    1,327
    I VOTE FOR IT'S UNDERNEATH. If it really bugs you make a pin hole and see if it will push out. Seal back up with what the mfr. recommends.
  10. #18
    Apr 2014
    Quote Originally Posted by DanaDetailingPros View Post
    Sorry, I don't follow. I can wipe it right off with Goof Off. It does take a part of the ceramic coating with it, but the mark goes away completely. If you mean air or water underneath the PPF, it is not, as I am quite familiar with what they look like.
    As I have written above, after the coating was fully cured over dried PPF, I went through the car with UV and they were not there. Also, they originated on the surface, visible to the eye, after the car had been sitting outside. They looked like a form of bird dropping. Lastly, air or water do not react under UV like biological material does.
  11. #19
    Super Member vobro's Avatar
    Jun 2012
    Homer Glen Il
    1,156
    I’d be more afraid of what the Goof Off can do to the ppf
  12. Likes Tasmania, Coatingsarecrack liked this post
  13. #20
    Jan 2017
    Tasmania, Australia
    911
    Honestly mate take it back to the PPF installer and ask the above questions
    Othe than that i think your mind is made up on what you want to do.
    And be thankful that people took the time to try and help you.
  1. Removing water spots from Ceramic coatings
    By ugafiredawg in forum Auto Detailing 101
    Last Post: 11-09-2022, 06:44 AM
  2. Replies: 3
    Last Post: 11-15-2020, 12:36 AM
  3. Advice for removing diluted road paint
    By Lakeside Detail in forum Auto Detailing 101
    Last Post: 08-15-2014, 03:45 PM
  4. Request for Advice
    By Helltopay in forum Auto Detailing 101
    Last Post: 01-19-2013, 02:48 PM
  5. Removing road-salt yellow-spots from paint!?
    By Ohio Detailing in forum Ask your detailing questions!
    Last Post: 06-03-2012, 11:53 AM
