Results 11 to 20 of 27
    Dec 2018
    7,180
    Re: Advice on my Spring routine
    Quote Originally Posted by 01AUDI View Post
    Thank you for the replies. Just to elaborate , I had done a good polish about 5months ago prior to my winter sealing. I did an entire iron remover, polish, seal, etc. and topped off with OCW throughout the winter with my normal washes.
    I would still use that process come spring, I am mainly looking for advice on whether these Wash and Wax products would be worth it ( due to the ease of using them) or if I should stick to my 3D Pink wash and then use some type of topper that would work well with the Deep Gloss.
    I see the recommendation for the Deep Gloss Spritz, but is that a topper or is that just a spray on version of regular Deep Gloss liquid? I would be using the topper every 2-3 weeks and don’t want to keep adding sealant over sealant.
    I was originally thinking of a Caranuba type topper for its shine. And since I would be applying this e dry 2-3 weeks. It would wear off by that point anyway so I would not be compounding product over product so much. Would something like the Wolfgang Uber Wash n Wax be any better or worse than the Spritz ?
    Wolfgang recommends it as a topper. In you case I would use the spritz once monthly ontop of wgdgps and then use WG spritz detailer every wash.
    As for glossy to top it there aren’t to many people left using WGDGPS and carnauba toppers. Sooo 2007’ish.
    Most have moved onto Sio2 products.
    The products I like for weekly top ups are P&S Dream Maker, Adam’s slick and slide (TecChoice 582 is same product) and my favorite but have to order from Canada is Tac Systems Shinee Wax. Last one would be my choice if I used DGP sealant.
    Also Griots Best of Show spray wax was nice couple times I used it.
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,016
    I'm debating on wether or not to give my car a light polish this spring.
    I haven't been diligent either, but it still looks great. Right now it's a test bed for Optimum stuff, but I have Opti-Seal on the majority of the paint.
    I did top everything off with OCW in the fall and have been doing ONR washes in the garage.
    I like using Optimum Instantant Detailer for a drying aid and for those times I want to baby the car after washing.
    The gf's Jeeep has Gloss Coat + Hyper Seal on it, so all it's going to need is a light decon wash and Instant Detailer.
    Mom's car has Opti-Seal and it will get the clay + Opti-Seal in the spring again. It's been doing a great job since I applied the last coat in the fall. But, the winter here in MI has been mild until today anyways!
  3. #13
    Dec 2018
    7,180
    Do you do detailing professionally? Just asking because you seem to be all I. On optimum products.
  4. #14
    Dec 2009
    217
    HaHa that’s funny.
    So if you say everyone is going to Si02, should I get the WF Uber Si02? Or is Spritz better for WGDPS ?
  5. #15
    Dec 2018
    7,180
    HaHa that’s funny.
    I’d stick with spritz.
  6. #16
    Dec 2009
    217
    Not to keep going, but I am truly interested, why the Spritz over the Si02? Is it because I’m using the DGPS or is there another factor that you’re making that suggestion based on ?
    I don’t get on here often so I’m truly trying to soak up the good knowledge of you all.
  7. #17
    Dec 2018
    7,180
    Just based on Wolfgang recommendations. The sio2 gets good review but I don’t no if it will adhere as well.
    Would I try it…. Yes…. Because I have personally not used these products I am making recommendations based of manufacturers suggestions.
    I personally would lay down a coating instead of WGDGPS
  8. Likes opie liked this post
  9. #18
    Dec 2009
    217
    Thanks!
  10. #19
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    NO WAY!!
  11. Likes Coatingsarecrack liked this post
  12. #20
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,227
    NO WAY!!
    Hey pap...take your old waxy sealant crap out back and burry it, get with the times! Hahaha
    pokeAdvice on my Spring routine
  13. Likes PaulMys liked this post
  1. Some advice on routine
    By NoClue in forum Auto Detailing 101
    Last Post: 09-04-2021, 05:40 AM
  2. Product advice on replacing Opti-Seal & OCW routine
    By AMarkham40 in forum Auto Detailing 101
    Last Post: 04-30-2021, 12:56 PM
  3. Looking for advice on a new routine
    By mightypudge in forum Auto Detailing 101
    Last Post: 05-16-2018, 07:53 PM
  4. Car Detailing Routine
    By worriedlearner in forum Auto Detailing 101
    Last Post: 04-08-2017, 10:06 PM
  5. DD Maintenance Routine?
    By JRivers in forum Auto Detailing 101
    Last Post: 08-04-2011, 01:50 PM
