Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    Jun 2017
    Water etched windows and paint help requested.
    Water etched windows and paint help requested.-902df95f-513b-4e01-8453-fc8d2439a6dd-jpegWater etched windows and paint help requested.-dd557b11-01dd-40c7-bf2b-6e318bbea4e7-jpegI purchased a LR4 with severe water etched windows and paint. Because the car is white the spots are not that noticeable to the average person but they irritate me. My windows though are pretty terrible as well as any trim. I have tried to fix the windows with vinegar, 0000 steel wool etc. nothing worked. On the paint I have tried claying as well as pinnacle swirl remover on my flex 3401. Nothing. Any suggestions? Thanks in advance.
    May 2013
    TN
    1,768
    Re: Water etched windows and paint help requested.
    Try CarPro Descale to remove the deposits.
    CARPRO Descale 500 ml
    For trim, I’d recommend picking up P21S Paintwork Cleanser which is a very mild polish and use with foam wax applicators.
    P21S Gloss Enhancing Paintwork Cleanser car polish - This pre-wax cleaner and polish is a German blend of quality ingredients that will make wax
    6 Pack Pinnacle Foam Wax Applicators
    For paint, you may need to go to a stronger polish or even a compound if real bad. I’ve tried most of the major polishes and my favorite medium compound is Griot’s Fast Correcting Cream and their Perfecting Cream gets good reviews. I like the Uro-Tec and Uro-Fiber pads on my CBeast, which is the nickname for the cordless version related to the Flex 3401.
    Griots Garage BOSS Perfecting Cream
    Griots Garage Fast Correcting Cream
    Dec 2018
    7,179
    I’d use Griots glass polish on windows. Removed all etched spots on some severely etched glass I had
    Griots Garage Fine Glass Polish
    Descale as Dgage suggested and also maybe a waterspot remover on trim and paint before polishing.
    CARPRO Spotless 2.0 Water Spot Remover 1 Liter
    Super Member Rsurfer's Avatar
    Jan 2007
    14,095
    Try what was suggested and if it doesn't work..use a rayon glass pad with some Ceriglass. As for your paint, use a mirofiber cutting pad and a good cutting compound such as 3D, Sonax or Griot.
    Super Moderator
    Feb 2022
    Try a glass polish like CARPRO Ceriglass Kit, glass polish, water spot remover. Use of a glass coating or sealant helps with preventing this problem as well DP Glass Coating or Diamondite Glass Sealant
    Nicholas • Customer Service
    Phone: 772.247.3420
    Nicholas@palmbeachmotoring.net
    Super Member luckydawg's Avatar
    Jan 2016
    1,117
    Water spots CAN ( not always ) get so bad they need to be wet sanded ( on the paint of course )
    First hand exp. speaking
    You might try spot polishing first with a small rotary if you have one-- dab something like M205 or shock cut on the spot and just work that very small area, then of course finish the whole area with the polish you would normally use
    Diplomacy is the art of telling people to go to hell in such a way that they ask for directions-- Winston Churchill
    The difference between genius & stupidity is genius has limits-- Albert Einstein
    May 2013
    TN
    1,768
    My wife’s minivan had real bad spotting on the passenger side and hood. Had to break out a Rupes blue wool coarse pad and Griot’s Fast Correction Cream but that finally did the trick. Uro-Tec UtoFiber pad would also work.
    Super Member DetailKitty's Avatar
    Jul 2013
    PA
    5,026
    I’m curious about the CarPro Descale!
    2022 Jeep Gladiator Rubicon • 2021 Ford Ranger Lariat •2016 Alfa Romeo 4C Spider • 2006 Buell Lightning-Bolt • 2004 Jeep Wrangler Rubicon
    Jun 2017
    Thanks everyone. I’m overwhelmed with the responses. I truly appreciate you all reaching out. I’ll keep you all posted.
  10. Likes luckydawg liked this post
  11. #10
    Jan 2016
    1,117
    Please do
  1. Getting rid of etched water spots
    By pilotpip in forum Auto Detailing 101
    Last Post: 08-12-2017, 04:55 PM
  2. Etched Water Spots on Paint
    By Lustrous Detail in forum Wet-Sanding, Cutting & Buffing
    Last Post: 09-02-2015, 07:11 PM
  3. Etched Water Spots
    By zinc02gt in forum Auto Detailing 101
    Last Post: 01-16-2010, 06:22 PM
  4. water spots etched into windows
    By Jay Laub in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 06-15-2007, 01:18 PM
  5. Etched water spots. help
    By Tex Star Detail in forum Auto Detailing 101
    Last Post: 12-13-2006, 02:27 PM
