Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    Jun 2022
    Reset Dilution Ratio?
    I just bought some CarPro Reset. The bottle instructions say to dilute 500:1 and gives an example of 1.35 ounces per 5 gallons. If I use it in a handheld pump foam sprayer with 1/2 gallon or less of water, that ratio works out to something like 1/10 of an ounce or less of Reset. It would be almost impossible to measure that small an amount. Am I missing something?
    Sep 2015
    2,173
    Re: Reset Dilution Ratio?
    Quote Originally Posted by dalemccl View Post
    I just bought some CarPro Reset. The bottle instructions say to dilute 500:1 and gives an example of 1.35 ounces per 5 gallons. If I use it in a handheld pump sprayer with 1/2 gallon or less of water, that ratio works out to something like 1/10 of an ounce or less of Reset. It would be almost impossible to measure that small an amount. Am I missing something?
    That dilution ratio is for a bucket wash. I've never used it out of a pump sprayer/foamer.....but I'm guessing maybe two or three ounces for 64 oz of water in a pump sprayer?
    Super Member Rsurfer's Avatar
    Jan 2007
    14,094
    Mix in a 5 gallon bucket and use as needed or use Echo2 as a waterless wash.
    Jan 2007
    14,094
    Quote Originally Posted by briarpatch View Post
    At that ratio it will strip his paint. LOL
  5. Likes Eldorado2k liked this post
  6. #5
    Super Member evo77's Avatar
    Mar 2008
    582
    Find an online dilution calculator. Enter the amount of the water. Enter the dilution ratio. Hit enter.
    Then convert the ounces (oz) to milliliter (ml) using another online converter. 0.1 oz is about 3 ml.
    Use those little measuring cups that come with your cold/flu/cough medicines. That is what I use.
  7. #6
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    You are going to have to experiment to figure out what you like. Start with the recommended dilution and adjust from there.
  8. #7
    Jun 2022
    Thanks for all the good info in your replies.
    I am starting to wonder if I should return the unopened Reset and get something else that doesn't have such high water to product ratios. Is Reset even appropriate for use in a handheld pump foam sprayer?
  9. #8
    Sep 2015
    2,173
    Before you return the Reset.....take look at this video from Brian at Apex Detail....using Reset in and IK pump foamer......might be helpful to you
    CarPro RESET!! The Car Shampoo Series...Continues!! - YouTube
  10. #9
    Sep 2015
    2,173
  11. #10
    May 2013
    TN
    1,768
    I use Reset in an IK Foam Pro 12, I think I used 2 or 3 ounces but I regret not paying more attention. Foams really well and is my primary wash style now other than when I use a rinseless. Meaning I like Reset foamed instead of Reset in a bucket.
  12. Likes CleanIT liked this post
  1. Dilution Ratio App
    By Abic in forum Tricks, Tips and Techniques
    Last Post: 08-27-2020, 03:54 PM
  2. Dilution ratio chart
    By frankprozzoly in forum Auto Detailing 101
    Last Post: 12-13-2015, 01:39 PM
  3. How-To: Dilution Ratio's
    By DLB in forum Tricks, Tips and Techniques
    Last Post: 06-01-2015, 06:05 AM
  4. Dilution ratio
    By Bicycle in forum Auto Detailing 101
    Last Post: 07-12-2014, 11:19 AM
  5. Dilution ratio
    By aztec1987 in forum Hot topics & Frequently Asked Questions
    Last Post: 06-27-2014, 05:21 AM
