Results 1 to 8 of 8
Thread: New tool for me
    Jun 2013
    Montreal, Quebec
    3,996
    New tool for me
    After watching a few of Yvan Lacroix' videos, I have decided to give the rotary polisher an other try.
    I purchased a Milwaukee Fuel cordless rotary today and will start using it as soon as tomorrow.
    The machine came with 2 waffle type polishing pads. They look like 7 or 8 inch diameter to me. They are white foam and look open cell so I am assuming they are polishing pads, not cutting ones.
    So my questions:
    1. What pads do you guys use on rotary for compounding?
    2. What pads do you use for polishing?
    Yvan promotes the use of the rotary to finish and the Long Throw DA to cut. Since I am trying to learn this tool I will probably do both with the rotary for a while to see how it performs compared to the DA.
    His technique is to use no pressure with very little products on a damp pad and setting the machine to minimum speed (800 RPM in the case of this specific polisher).
    I have 2 3 amps batteries and I am hoping this will be sufficient to be able to do most jobs. I have not tested how long they last yet, now how long it takes them to charge but rotaries use less power than DAs and modern cordless DAs seems to be able to work almost non-stop with a 2 battery+charger system.
    All right, any advice regarding this is welcome. Yvan sold me to the idea why explaining you can get a better finish with a rotary if you have the proper technique, and on top of that it's faster to do.
    Super Member opie's Avatar
    Mar 2021
    Pa
    2,230
    Re: New tool for me
    Rupes twisted wool coarse blue pads for the most heavy cut. Lake country purple foamed wool pads for when i dont need the max cut, and closer to lsp ready finish.
    For small 3 inch work, lake country blue foamed wool pads, lake country force orange/white pads.
    Im not one of those few talented folks out there that can humbly finish down or errogantly claim to finish down with a rotary just as good or better than a da machine. Even if you take your time polishing with a rotary you will still in my experience see a little haze.
    So far in my time, i save the rotary for the heavy grunt cut work and bring out the flex forced rotation da for the finish work to give the client or myself the best finish possible
  3. Thanks Calendyr thanked for this post
    Likes fly07sti liked this post
  4. #3
    Super Member fly07sti's Avatar
    Sep 2013
    SF Bay Area, Cali
    2,939
    Re: New tool for me
    ^^^I am right there with you Opie. The Rupes twisted wool is an awesome pad and cuts like crazy but finishes ok for how heavy it cuts and the speed at which is does also. I have yet to need a medium polish to remove holograms or haze. Most other twisted wool pads will need that step.
    Now depending on the paint I’m working on, I will finish with a GG6 forsoft paint, Flex3401 or Rupes 15 for medium to hard paint.
  5. Thanks Calendyr thanked for this post
    Likes opie liked this post
  6. #4
    Jun 2013
    Montreal, Quebec
    3,996
    Re: New tool for me
    Thanks guys.
    Tried the polisher yesterday. Wasn't too bad but since I only have flat pads, I was fighting the machine a lot to keep it from bouncing and flying around. Gonna need to buy waffle type pads which are not supposed to do that on a rotary.
    So my first impression is that cordless is awesome As for efficiency, I am disapointed. It took me longer to do the hood than it would have taken with a DA. Maybe that is because of the low speed on the machine, I was using 800 RPM which is the lowest setting. When I get new pads, I will try again and maybe it will be faster without the pad always trying to grab the surface and go where it wants.
  7. #5
    Mar 2021
    Pa
    2,230
    Re: New tool for me
    Quote Originally Posted by Calendyr View Post
    Thanks guys.
    What size pads were you using?
    And you need to be firm with your grip on the machine, you control it, dont let it control you. Either lean the machine a tick so you are favoring one side of the pad, and or push with enough downward force evenly on the entire pad surface so the machine doesnt walk on you.
    If your coumpounding atleast 1200rpm, polishing you want less
  8. #6
    Jun 2013
    Montreal, Quebec
    3,996
    Re: New tool for me
    Using 5.5" pads. Trying to keep it as flat as possible. I have seen Yvan barely holding the machine while polishing, so I think the pad makes a huge difference. While I was using it I had to use a lot of force to keep it from moving in all directions.
  9. #7
    Mar 2021
    Pa
    2,230
    Re: New tool for me
    With a rotary, larger pads(6.5) or larger make a huge difference in the machine wanting to walk around on ya
  10. #8
    Super Member dlc95's Avatar
    May 2013
    Rochester Hills, Mi
    6,019
    Re: New tool for me
    I used to use the Meguiar's W-4000 or old burgundy foam for cutting, and their yellow for polishing / finishing. I did have their tan back in the day but didn't use it much.
    More recently I was using the blue Buff and Shine to polish/finish.
  11. Likes luckydawg liked this post
  1. Replies: 15
    Last Post: 12-05-2016, 09:10 AM
  2. What tool box/bag are you using?
    By RangerDetails in forum How to make money detailing cars
    Last Post: 06-06-2016, 07:44 PM
  3. What is this tool??
    By Jim w in forum Auto Detailing 101
    Last Post: 04-26-2016, 05:16 PM
  4. What tool to get next?
    By banzaitoyota in forum Auto Detailing 101
    Last Post: 07-20-2015, 05:47 PM
  5. Tool boxes!!!! What's everyone use for mobile tool boxes???
    By pony420s in forum Auto Detailing Tools and Accessories
    Last Post: 01-06-2015, 07:07 PM
