Results 1 to 7 of 7
    Jun 2022
    Pads stained from 3D speed?
    Hi everyone - picked up some 3D speed and used it on a couple different cars in the last week. First I used it will white CG hex pads and second with yellow rupes pads. My white CG pads are now pink and my yellow rupes pads are orange. I've always washed my pads under warm water with pad cleaner and always got the pads back to the original color. I soaked a rupes pad face down in a mix of water and pad cleaner for 6 hours and it's still orange. Is this just normal with 3D speed? I assume I can continue to use these pads without issue?
    Super Member Dr Oldz's Avatar
    Aug 2010
    NE PA
    4,462
    Re: Pads stained from 3D speed?
    Continue to use them. No big deal.
    Jim
  3. Likes PaulMys liked this post
  4. #3
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,772
    Totally normal.
    You're good to go.
  5. #4
    Aug 2013
    St Louis metro (Illinois)
    5,836
    I haven't used 3D products, but totally normal. Other polishes do it too. Hyper polish stained my white pads pale blue. The older Blackfire and Wolfgang polishes are purple and made all of my white pads gray.
    Not sure why companies color their products. Since there are plenty of good ones out there which are white, it doesn't seem to be needed.
  6. #5
    Mar 2017
    Southeastern PA
    2,480
    Agreed, just make them white. Maybe they do it for easy to identify if you switch bottles or if you have product on a pad and you lost track if that's compound or polish but if that's the only reason, it's not enough. White would be fine.
    Bruno Soares
  7. #6
    Aug 2013
    Tustin, CA
    4,389
    Normal. You are good to go
    CJ
    Save the Manual!
  8. #7
    Super Moderator Bobby B.'s Avatar
    Sep 2009
    2,355
    Yes, that's normal with 3D HD Speed.
  1. Had speed stained trim?
    By jarabian52 in forum Auto Detailing 101
    Last Post: 01-19-2021, 10:58 PM
  2. Dye stained buffing pads?
    Last Post: 09-22-2019, 04:51 AM
  3. HD Speed ... Purple Stained Pads
    By Scott in Houston in forum Auto Detailing 101
    Last Post: 06-14-2019, 07:05 AM
  4. Washing machine stained my Surbuf pads!
    By TimmyG in forum Auto Detailing 101
    Last Post: 04-14-2012, 12:31 PM
  5. Polishings pads stained by M06
    By BenSRT in forum Ask your detailing questions!
    Last Post: 09-13-2010, 08:38 AM
