Results 1 to 9 of 9
    Jun 2022
    Doing a paint correction. Couple questions
    Hello, I own a 2016 Shelby GT350 in competition orange. I brought my car to have paint corrected, but it seems like they just did a polish/sealant. The car has very minor swirls in the paint, that you cant see unless looking within 3' in direct sunlight.
    I had a Supra I had done a paint correction on before that came out really good. But that was a couple years ago. Couple quick questions. I have some Pinnacle compound, wolfgang total swirl remover I figured I would start off light to take off any swirls. I dont think Ill need the compound with a heavy cutting pad but we will see.
    I was planning on using Sonax Profiline nano polish 3/6, follow it up with Wolfgang Perfekt finish paint prep, and then Wolfgang Si02 Paint sealant. Will this be okay? From what Ive gathered the sonax polish is very glossy, and the wolfgang Si02 is also very glossy and gives a good amount of protection. Not sure if the perfekt finish prep is necessary?
    Thanks!
    Super Member luckydawg's Avatar
    Jan 2016
    1,117
    Re: Doing a paint correction. Couple questions
    Well what I would do is after you do your normal wash- I would clay the entire car. I am thinking you can save a tad bit of $$ and use the Wolfgang product that you already have, with a medium pad (Rupes yellow-of course do a test spot first ). Then do a good wipe down with a good IPA solution , and finish it off with your LSP ( WG Sio2 )
    That should get you
  3. Likes dlc95, PaulMys liked this post
  4. #3
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,773
    Can you provide us with any pics?
    Oh, and welcome to AGO.........
  5. Likes DETAILROOKIE liked this post
  6. #4
    Apr 2020
    Dayton, OH
    142
    The Perfekt Finish Prep is called for when using Wolfgang SiO2 Paint Sealant - it will remove any polishing oils and allow it to bond properly to the paint. In reality, you could probably use any IPA wipe down product, but since you already have the Perfekt Finish, might as well roll with that.
    Otherwise, Total Swirl Remover is some pretty good stuff, I'd try that on the swirl marks with a few different pads and see if that knocks it out.
    Sounds like a cool car.
    -Adam
  7. #5
    Aug 2013
    St Louis metro (Illinois)
    5,809
    I think the polishing products you already have on hand should be just fine, Wolfgang Swirl Remover is a good polish and you can pair it with different cut levels of pads to adjust the results a bit depending on what you need. I'd start with a medium cut pad like Lake Country White Thin Pro's as a starting point.
    Wolfgang SiO2 Paint Sealant is a great choice and I really liked using it. It does leave a very shiny finish and it had the longest durability of any sealant I've used. You can use products other than Perfekt Finish Prep as a final wipe down. I used CarPro Eraser and it worked just fine. I think the important part is to remove the polishing oils before application of the sealant. Pick your poison. Does using a panel wipe change anything with the sealant? Don't know. I did it because the product instructions recommend it and doing that step only takes a few minutes, however I've never done a panel wipe before applying any other sealant and was always happy with the results and the durability.
  8. #6
    Super Member Bdubbs's Avatar
    Apr 2020
    357
    Does your 350 have stripes? I plan on doing a paint correction on my 19 350, but not until winter.
    I really like Wolfgang products. I've been using their Uber compound more than the total swirl remover. I use lake country white and orange pads.
    Sent from my moto g power (2021) using Tapatalk
  9. #7
    Jun 2022
    Quote Originally Posted by luckydawg View Post
    That should get you
    Thanks, I actually already ordered a bunch of the stuff
    I do not have any pics at the moment, but I will get some soon
    Quote Originally Posted by waddell64 View Post
    -Adam
    Thanks for the advice, I appreciate it!
    Cool good to know. Yeah the Si02 seems really good. I havent seen anything bad about it.
    Quote Originally Posted by Bdubbs View Post
    It does, its competition orange with black stripes. The stripes are screwed. I may end up just replacing them. Although I have PPF on the front and rear bumper. Why the rear bumper but not the hood is beyond me, lol.
  10. #8
    Super Member 2wookies's Avatar
    Jul 2015
    367
    Did you pay for a correction or a polish and seal? Maybe talk to the shop that did the work and explain it’s not up to your standards.
    What machine/pads do you have?
  11. Likes dcjredline liked this post
  12. #9
    Jun 2022
    Quote Originally Posted by 2wookies View Post
    I did. Id rather not go back honestly. My gut told me to just do it myself, should have listened lol.
    I had the porter cable, and then I just ordered some new Lake Country CCS pads. I ordered Orange, white, blue and black. I doubt Ill need the orange, but I figured just in case
  1. Paint correction questions on my G37
    By Andrewm in forum Auto Detailing 101
    Last Post: 04-23-2017, 01:15 PM
  2. New to paint coatings...couple of questions
    By Zune in forum Auto Detailing 101
    Last Post: 05-28-2015, 04:23 PM
  3. Replies: 17
    Last Post: 01-13-2013, 08:51 PM
