Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Dec 2017
    481
    Ceramic light coatings
    Hi was wondering if these coatings wear off or do they require polishing?
    Currently using WG Ceramic Spray Coating.
    Is there any light ones that don't wear off?
    Super Member BadgerRivFan's Avatar
    Aug 2015
    Mt. Horeb, WI
    884
    Re: Ceramic light coatings
    They all wear off Pete, even the “full” ceramic coatings… it’s just a matter of how long it takes.
    Depends how much the vehicle is out in the elements, and what that environment is like.
    ​Al Schmidt
    "Adventure, is a car called Riviera..."
  3. Likes Desertnate liked this post
  4. #3
    Super Member Rsurfer's Avatar
    Jan 2007
    14,096
    Like Badger said, they all will wear off. The spray on coatings are not as durable as the wipe on, wipe off are.
  5. #4
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Exactly. They are all semi-permanent. The real coatings will last longer and be more durable that what you’re currently using which looks to be more of a spray sealant.
    CanCoat and Cquartz Lite are more like true coatings.
  6. #5
    Dec 2017
    481
    Thanks.
    I do polishing by hand which one would be best Cancoat or Quartz Lite.
    I thought Wolfgang Ceramic Spray Coating was a ceramic lite.
  7. #6
    Dec 2018
    7,179
    Quote Originally Posted by PeteT19640 View Post
    Thanks.
    I feel from what I ‘ve read it is alot like Adam’s graphene spray coating. Stronger than most Sio2 Sealants but not quite a coating lite.
    How long have you had it and how’s it performing.
    I haven’t used Cquartz lite and probably never willl because Gyeon CanCoat is an awesome product for a coating lite.
    You can now use it outdoors and has a 1 year rating. I got almost a year of great performance out of the old one rated 6 months.
  8. #7
    Jun 2013
    LA, CA
    8,719
    Thanks.
    Both are good options. If you have a garage then Lite. If you don’t then CanCoat Evo topped with Cure just as insurance policy.
    Both coating will perform longer than their claims.
    Might be time for a polisher to save your shoulders and get better results.
  9. Likes Desertnate liked this post
  10. #8
    Dec 2017
    481
    What is the difference between Cancoat Evo & Cancoat Evo Pro any extra work involved?
    Where can I get these. Autogeek don't have any yet.
    What the advantage Lite has over Evo?
    How long do they last once opened, I will only have x1 car to coat at the start?
  11. #9
    Dec 2018
    7,179
    For CanCoat vs CQ lite you will here both are great and some prefer one or the other. ClamCoat Evo jas benefit of being applied out side.
    CanCoat Pro is there Professional only version of CC evo. Regular consumers can not get. You can google gyeon CanCoat Evo if you want to see who sells it currently.
    If like old CanCoat Gyeon states 12 months if stored right.
    That is my problem with coating Lites. I only have 2 vehicles that I would apply to and even if I coated each twice in a year I would have half left over. Wish they made a can half the size for $39.99.
    Reason i got into full coatings. Not too much harder to apply nowadays…. Longer durability and will use all the product up.
  12. #10
    Super Member Paul A.'s Avatar
    Dec 2007
    Tampa Florida
    5,274
    My problem with Can Coat is i can't use the whole bottle before the 3 supplied sprayers go t**s up. Tried everything from storing in water after use to sucking acetone through them.
    I do simply find another sprayer and keep plugging through the bottle.
    Don't get me wrong...I LOVE Can Coat!
  13. Thanks Dan Tran thanked for this post
    Likes dgage liked this post
  1. Ceramic Coatings?
    By cburbs in forum Auto Detailing 101
    Last Post: 12-13-2020, 02:02 PM
  2. Ceramic Coatings
    By mwemaxxowner in forum Auto Detailing 101
    Last Post: 07-24-2016, 05:07 PM
  3. Ceramic Coatings
    By 2011 Kona Blue in forum Wolfgang Car Care
    Last Post: 05-07-2016, 07:48 PM
  4. ceramic coatings
    By bguiliano in forum Ask your detailing questions!
    Last Post: 08-17-2015, 06:44 AM
  5. Automotive Blog Shining Light on Coatings
    By AC in OC in forum Off-Topic
    Last Post: 06-11-2014, 04:08 PM
