Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Newbie Member Curvette's Avatar
    Sep 2021
    Which to use first, iron remover or water spot remover?
    Hey everyone, new to the forum and want to know which to use first. I just purchased a 2007 Corvette Z06 that has spent at least the last 5 years outside here in Seattle. It is waterspotted and the finish desperately needs work. I plan to use iron remover and water spot remover but want to know which one to use first before I clay and polish. It is dark blue if that matters and will now be garaged full time after I coat it. Any advice appreciated.
    Super Member Rsurfer's Avatar
    Jan 2007
    14,100
    Re: Which to use first, iron remover or water spot remover?
    If your planning on polishing, you won't need a water spot remover. The polish if aggressive enough will remove the water spots.
  3. Likes PaulMys, Coatingsarecrack liked this post
  4. #3
    Super Member PaulMys's Avatar
    Jan 2014
    Eastern L.I. NY
    10,772
    ^^This^^
    Got any pics? How bad is the water spotting?
  5. #4
    Mar 2017
    Southeastern PA
    2,480
    Water spot removers only work on fresh ones and even then, most of the times end up disappointing. Like mentioned above, the abrasion from polishing should remove the water spots and if any remain, step up in aggressiveness (pad and/or product).
    Bruno Soares
  6. #5
    Sep 2021
    I don’t have any pics of the water spotting and it’s raining right now. So I should use iron remover, forget the spot remover and just polish out the spots after claying.
  7. Likes Coatingsarecrack liked this post
  8. #6
    Jan 2007
    14,100
    Quote Originally Posted by Curvette View Post
    You got it, now get to work.
  9. #7
    Jan 2014
    Eastern L.I. NY
    10,772
    Iron remover, wash, clay, and polish.
    Are you machine polishing? (I hope)......
  10. #8
    Sep 2021
    Yes I’m using a griots DA with orange pad. Here’s the car.
    Which to use first, iron remover or water spot remover?-8f42c8c8-9e76-4b95-8cb0-cf0faa556857-jpeg
  11. #9
    Super Moderator Bobby B.'s Avatar
    Sep 2009
    2,355
    Awesome car! I would love to own a C6 ZO6.
    More than likely the water spots have etched the surface. I would do a test spot to see if your polish will remove the water spots. You may have to start with a compound to remove the etched water spots and then polish the surface before you prep for a coating.
    Iron Remover
    Wash
    Clay
    Compound
    Polish
    Prep Spray
    Ceramic Coat
  12. Likes fly07sti liked this post
  13. #10
    Jan 2014
    Eastern L.I. NY
    10,772
    Quote Originally Posted by Bobby B. View Post
    Iron Remover
    Wash
    Clay
    Compound
    Polish
    Prep Spray
    Ceramic Coat
    If you use something like Griot's Fast Correcting Cream, you can knock out the compound/polish in one step.
    The FCC finishes down so nicely, you rarely need to chase it with a finishing polish. Awesome product!
    Which Griot's machine do you have?
  1. Water spot remover
    By carlg in forum Auto Detailing 101
    Last Post: 05-06-2018, 03:31 PM
  2. Looking for a Water Spot remover
    By Automoglow in forum Auto Detailing 101
    Last Post: 01-17-2018, 09:20 PM
  3. Water spot remover
    By Paulyfe12 in forum Auto Detailing 101
    Last Post: 05-26-2014, 12:33 AM
  4. best water spot remover?
    By kjimpressions in forum Auto Detailing 101
    Last Post: 03-25-2012, 08:36 PM
