Page 5 of 5 FirstFirst 12345
Results 41 to 47 of 47
  1. #41
    Mar 2021
    45
    Re: Electric pressure washers
    'But wait there's more'
    Is a 'constant' duty cycle really that ? one would think so but sadly this isn't so or is it ?????????????
  2. #42
    Super Member Azure's Avatar
    May 2013
    Indianapolis, IN
    405
    Quote Originally Posted by PearTree View Post
    In the context of using a pressure washer for detailing, I don’t see duty cycle as something that matters. In my use, my pressure washer pump isn’t in use for more than 3-5 minutes at most and that’s for the initial rinse or foam gun use before turning off.
    If you were planning on using the pressure washer for driveways, decks, exterior house use, etc. then I could see duty cycle being important. But an electric pressure washer wouldn’t be something I would use for those purposes anyway.
    I would say being at the ready (pressurized - pump powered but not running) is something to consider as it certainly would add stress to any seals within the pump. That probably should be included in a duty cycle since technically it has to be powered on to maintain pressure.
  3. Likes PearTree liked this post
  4. #43
    Aug 2022
    Dana Point CA
    1,327
    Anyone hear have a Active 2.0 Pressure Washer? This is there newer upgrade. I only see good reviews on it with YouTuber's that will say anything good for free swag
    I have a nice gas model and never like bringing it. I wish the Kranzel 1050 was available in US in 110ac
    I like the AR but again 75lbs. No thanks!
    I just like the small size and minimalist look on there new model.
  5. #44
    Sep 2020
    Eastern PA
    1,824
    I saw a few reports on Facebook of them dying after limited use.
  6. Likes Bosko, chilly liked this post
  7. #45
    Aug 2022
    Dana Point CA
    1,327
    I just wanted to double check MisterSnoop. Was it the old model or the new 2.0? I do know the first ones had problems!
  8. #46
    Sep 2020
    Eastern PA
    1,824
    Quote Originally Posted by DanaDetailingPros View Post
    Rereading the comments... It looked like 1 failure on the 2.0 (the original post). The other one mentioned was a VE51.
  9. #47
    Aug 2022
    Dana Point CA
    1,327
    Quote Originally Posted by MisterSnoop View Post
    BEST PRESSURE WASHER FOR MOBILE CAR DETAILING SET UP? | Active 2.0 - YouTube
  1. Reliable Electric pressure washers
    Last Post: 02-15-2019, 01:52 PM
  2. PRESSURE WASHERS (electric self priming)
    By 215Detailing in forum Off-Topic
    Last Post: 12-27-2017, 09:53 AM
  3. Need to Pick up 1-2 Electric Pressure Washers(Fairly Cheap)
    By ShineTimeDetail in forum Off-Topic
    Last Post: 07-30-2012, 09:30 PM
  4. Pressure Washers
    By TotalNewbie in forum Hot topics & Frequently Asked Questions
    Last Post: 05-26-2012, 04:10 PM
  5. Pressure washers: What do you use them for?
    By DonMTV in forum Auto Detailing 101
    Last Post: 12-31-2009, 08:51 PM
