Results 11 to 20 of 22
    Super Member psnt1ol's Avatar
    Aug 2012
    San Francisco
    892
    Re: What Polisher should I get? curvy panels
    Quote Originally Posted by clidefr0g View Post
    im concerned that a g8 or similar 3" polisher would still be too large for a bunch of spots on my car, I was really hoping someone with experience doing an F type could weight in as well.
    Theres a rupes nano long neck for sale second hand near me for about 50% off retail atm but id be hard pressed to want to do the whole car with a 2" polisher?
    the G8 comes with a 2" backing plate as well.
    Aug 2012
    San Francisco
    892
    Scrubbing tires with a corded machine is not safe imo. Using a cordless drill for tires is a safer way to clean your tires. Plus a rotary will not stall like a DA will.
    I hear what you are saying.
    I only use heavy gauged marine grade extension cord. The amount of cleaning liquid I used is just a tad more than what I would use when wet sanding with a DA. Rubber soles , rubber mat, and rubber gloves are used.
    I rinse with power washer only when all the scrubbing has been completed.
  3. #13
    Dec 2018
    7,192
    If your worried about stalling on curves go forced rotation. A flex product.
    You could also look to take a class and learn how to get a free spinning DA to “dance” on the paint.
    I fear if you have stalling issues with your PC, you may also have it with the Griots or that matter most DA’s.
    A Mini 3” and Nano would still be great for tight spots.
  4. #14
    Super Member mc2hill's Avatar
    Feb 2009
    Orlando
    553
    Like others have said - go to a Flex forced rotation.
    I have a Rupes 15 MKII and a Rupe Mini, and they always worked fine...until I did a few Porsche cars & SUVs. The curves stalled the 15, so I ended up doing 1/2 the car with the Mini. A Flex would have made the job much easier.
  5. #15
    Aug 2013
    St Louis metro (Illinois)
    5,821
    I attacked the problem in a couple different ways: Tools and pads.
    Pads: Before I went with a two-tool set up I kept a combination of different pads and swapped them out as needed on my primary, "big" polisher. To this day, I still do this depending on the surface I'm working on. For larger flat areas like a hood or trunk deck, I'll use thinner pads. For curvy areas like fenders, some doors, running boards, etc, I'll use a thicker pad which will conform better to the irregular surface and make it easier to keep the pad flat on the surface.
    Tools: I ended up going with a two-tool set up. Right now I've got a G15 and a G8 and it covers all the bases for me nicely when used in conjunction with a combination of pads.
  6. Likes oneheadlite, PaulMys liked this post
  7. #16
    The three tools I predominantly use when I buff out most cars are,
    FLEX Supa BEAST
    RUPES Nano Long Neck in Rotary Mode - 1" pad
    FLEX PiXiE with the 12mm orbital connector and a 2" backing plate with a 3" foam pad
    Here's an example of where I use the Nano Long Neck
    Paint Correction - George Harrison's 1966 Ferrari 275 GTS - Pinnacle Jeweling Wax & Souveran Paste Wax
    Here's everything I used....
    Just an old 2-door European job....
  8. Likes Bruno Soares, SENC7 liked this post
  9. #17
    Here's another example of where and how I use the RUPES Nano Long Neck
    Doing Edge Work with RUPES Nano in Rotary Mode - Mike Phillips Style
    Just another old 2-door European job....
  10. #18
    Junior Member clidefr0g's Avatar
    Sep 2011
    38
    Beautiful car!
    Thank you for your input Mike. I see you're using the cordless versions in your picture, do you prefer them over the corded machines? Could you link me to the supa beast that you recommend?
  11. #19
    Mar 2017
    Southeastern PA
    2,480
    Beautiful car!
    See post #4 where I provided the link for the Supa BEAST
    Bruno Soares
  12. Likes PaulMys, clidefr0g liked this post
  13. #20
    Beautiful car!
    Here's an article I wrote about the FLEX BEAST Family.
    FLEX Power Tools Nicknames - All cool tools should have a nickname - not a part number -Mike Phillips
    Here's what I wrote in post #3 - on 05-21-2020, 09:42 AM and I still think the same way.
    Here's my take on the above 3 gear-driven tools
    The BEAST
    If I REALLY want to bust out a job and plow through it as fast as humanly possible I use the BEAST.
    The Supa BEAST
    If not trying to hit Warp Speed - I grab the Supa Beast, much more enjoyable to use. Amazing tool. Smoother, quieter, lighter and cooler than the original.
    The CBEAST
    If I have an easy job, that means the car has only light swirls, scratches, etc. and I'm not in a hurry then I grab the CBEAS
    Here's what I use about 99.9% of the time.
    The SUPA BEAST
  14. Likes clidefr0g liked this post
  1. Test Panels?
    By asap2stacks in forum Auto Detailing 101
    Last Post: 08-16-2017, 01:05 PM
  2. Paint correction in small "curvy" areas?
    By Kinalyx in forum Auto Detailing 101
    Last Post: 12-08-2011, 07:16 PM
  3. DA on a Curvy Car
    By HotRodJoe in forum Auto Detailing 101
    Last Post: 09-14-2011, 05:55 PM
  4. PC on curvy Volvo
    By weeble in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 09-25-2009, 01:02 PM
  5. In between panels?
    By Texas Dave in forum Porter Cable 7424XP Dual Action Orbital Polisher
    Last Post: 10-29-2008, 11:10 AM
