Results 21 to 30 of 33
  1. #21
    Regular Member crg001's Avatar
    Oct 2020
    Redlands CA
    171
    Re: 2006 Toyota Sequoia - Comet Wash - Extreme Makeover - BLACKFIRE One Step
    Agree.
    For some cars, where the paint inside the emblems is dirty, oxidized and neglected, I use the Horse Hair Brush on the Nano to machine scrub this area.
    • Sometimes with soap and water.
    • Sometimes with an APC and waterless wash
    • Sometimes with Glass Cleaner.
    And sometimes, (and that would be this instance), I use a one-step cleaner/wax i.e. BLACKFIRE One Step. I just plaster some One Step into and around the emblem and then go nuts on the emblem with the Nano and Horse Hair Brush in rotary mode.
    It cleans the hell out of the paint and the emblem.
    Then I take the Tornador Black Air Blow Out Gun and blow and wipe and blow and wipe and blow and wipe.
    By the time I'm done - it looks brand new again.
    Again - apologies for no pictures. So often I do a lot of complicated and/or out of the box type work and take pictures and after investing the time to take the pictures and then create a detailed write-up - zero comments. So sometimes I become disheartened and just don't care to take pictures.
    Thanks for sharing, Mike! That seems like a pretty efficient way to get the emblems cleaned out! I always struggle with those. Usually I wash them with APC and a hand brush during the pre-wash but it's so hard to get all the crud out between the small spaces.
    Recently I tried something new on them that worked pretty well. I used 3D's Eraser water spot remover gel on a brush and scrubbed inside those things, then rinsed immediately after. Got the hard water stains out pretty effectively. I'll have to try the One Step method!
    Colin Lang
    @DimensionalShine <- My Detailing IG Page
  2. #22
    Quote Originally Posted by crg001 View Post
    It works really good in the context of the project. I wouldn't use this approach on a new car with a basecoat/clearcoat paint system as it would likely scratch the hell out of the paint inside the emblem and outside the emblem.
    This was a NEGLECTED car for 7-8 years. Whatever I did couldn't be any worse than it already was. So in context, this brush on a rotary polisher worked great.
    Here's something similar I did about 6 years ago... I broke a lot of conventional rules with this project.
    Before & After - 1961 Plymouth Fury Barn Find
    Sprayed an iron remover on the paint around a chrome emblem...
    Blasted and agitated with the Tornador Blow Out Gun
    Resprayed area with a waterless wash and then blasted again and also agitated paint with brush bristles...
    Just like new...
    I detailed the above car in December of 2015 - I don't believe the RUPES Nano had been invented yet or I would have used it in conjunction with the Tornador Blow Out Gun.
  3. #23
    Super Member Me Time's Avatar
    Apr 2016
    Louisville The Derby City
    219
    White definitely does not shine or look as deep as the darker colors, but it does seem to stay clean longer. I have had 3 black vehicles, and each time I said never again. But IMO nothing looks as good as a black car all shine up.
    Or, even some of the dark reds and blues of today.
  4. #24
    Jul 2014
    246
    One of the biggest reason I have so much respect for @Mike Phillips is he's not afraid to tell you how he got here..... Most detailers or influencers always hype the newest and cringe at the past.
    Sent from my SM-N986U using Tapatalk
  5. Thanks N/A thanked for this post
    Likes N/A liked this post
  6. #25
    Jan 2014
    SoCal
    1,122
    One thing for sure, with a modern URETHANE single stage paint system like Toyota uses, (not old school lacquer or enamel paints), your car will NEVER get clearcoat failure.
    There's no secondary layer of paint to fail or disintegrate. The single stage Toyota urethane paint system will OXIDIZE - but ALL of us can fix oxidation.
    None of us can fix clearcoat failure. When a basecoat/clearcoat paint system fails or disintegrates - the only true and honest fix is to repaint the car.
    For this reason - a single stage paint system trumps the basecoat/clearcoat paint system.
    That is a great question and knowing what I know now? I would opt for a single stage urethane paint system, probably in orange.
    Great questions... thank you for asking.
    Are you the guy in Eugene, Oregon?
    Naw, different Ducks (Ice hockey). I'm in SoCal.
    Thanks for the insight. For someone who likes to work on paint, I wondered if there was a good reason to avoid the new urethanes in place of BC/CC. Good to know going forward. This opens up new opportunities.
  7. #26
    Quote Originally Posted by ducksfan View Post
    I was curious of your take on single stage paint vs. base coat/clear coat in our present times.
    I'm in SoCal.
    Copy that. There was a guy that lived in Albany, Oregon that had me detail his Corvette, later he moved to Eugene, Oregon and I thought I remembered he was a member of this forum or the Meguiar's forum and I have/had been conversiong with him for years.
    Had a similar forum name if I remember correctly - and I probably don't.
    It's all good...
  8. #27
    Aug 2013
    St Louis metro (Illinois)
    5,836
    Amazing transformation on the car. I would never have thought to use Comet on a car...heck I haven't used Comet in decades since I haven't lived anywhere with ceramic tubs/sinks.
    Mike: I noticed you said Comet is a secret weapon you use on single stage paint. Do you use it only on white or would you use it on other colors as well. I'm sure the abrasion would be pretty frightening to see on a darker color...even if you know it will be polished out. Also noticed you coated the vehicle after using One Step. Won't the sealants in the One Step cause issues with the coating you applied afterwards?
  9. #28
    Super Member RTexasF's Avatar
    Jun 2006
    North TX
    2,582
    Your results are really quite remarkable. Having dealt with the Toyota single stage white in the past I admire your perseverance to get the job done in a single day. The one I dealt with with was a Corolla not the monster you brought back to life. Your work turned out far better than mine as I only had a PC to work with back then and Comet was never heard of for SS white paint. You indeed brought new life to that big 'Yota in every aspect. Your friend is in your debt.
    Rick....now in North Texas
  10. #29
    Quote Originally Posted by IH8SPM View Post
    Thank you for the compliment. My mom and dad instilled a good/strong work ethic in me from an early age, that is picking strawberrys and beans to pay for my own school clothes starting at the age of 5 or 6 if memory serves me correctly. I didn't miss a year, (picking berries and beans), until I turned 15, got a work permit, (don't even remember what that was about back then?), and then got a job at a full service Mobile Gas Station. I rode my bike to work until I got my driver's permit.
    I think it's harder for kids to get jobs like I had when I was a kid due to automation and progress.
  11. Likes IH8SPM liked this post
  12. #30
    Super Member Azure's Avatar
    May 2013
    Indianapolis, IN
    401
    The Comet wash was intriguing to me. Do you think Comet washing headlights are a good idea if you are planning to restore them? I suppose the sanding step kind of nullifies this possibly..?
  1. inspired by KISS Detail - Extreme Makeover- Toyota Highlander
    By expat2006 in forum Ask your detailing questions!
    Last Post: 03-22-2021, 01:02 PM
  2. RUPES EASY GLOSS System - EXTREME MAKEOVER - 2006 Toyota Tundra - YEARS of neglect!
    By Mike Phillips in forum PICTURES: Wednesday Night Detailing Classes
    Last Post: 03-19-2019, 08:18 AM
  3. Live Broadcast Thread - 2006 Redfire Mustang GT - M105/M205 Twins - Extreme Makeover
    Last Post: 09-07-2012, 10:47 AM
  4. KISS Detail - Extreme Makeover - Toyota Highlander
    By Mike Phillips in forum Show N' Shine
    Last Post: 07-14-2012, 10:32 AM
