Getting concave areas swirl free
Hello everyone,
I'm starting to get a bit frustrated with concave areas where I can only fit really small pads in, like 1" for example. (lower sideskirts of my BMW F20)
No matter what I try, using the softest pad and a Koch Chemie finishing polish, I can't finish hologram free. I ended up finishing this area by hand.
But I'm wondering what do I do wrong? I basically have to lean the pad from side to side to match the curve, so I can never have the pad flat in this area. I tried lower speeds, less pressure (to almost no contact). It's just not happening.
Here you can see the sideskirts pretty well: https://i.pinimg.com/originals/ef/cd...9a97eba2c9.jpg
Re: Getting concave areas swirl free
Are you using a rotary? By your description it sounds like it.
If you're not happy with the process and results of the small pad, try a larger pad on edge.
Or continue to do that area by hand... I know a lot of people, including Mike, that like to use a machine for polishing whenever and wherever possible, but some areas are better suited to hand polishing. I do it all the time.
Yes, using a rotary. I guess I have to live with hand polishing then for certain areas.
I'm wondering though what exactly causes the holograms to appear a lot easier when the pad is tilted? The increased pressure because of the small contact area?
I got my problem solved. Using the softest pad I have, which is usually meant to apply waxes and coatings and buffing extra long until the polish was completely clear. Took quiet some time, but still better than hand polish.
By Trevine in forum Ask your detailing questions!
Last Post: 01-30-2019, 08:43 AM
By 02SOMSS in forum Auto Detailing 101
Last Post: 03-17-2017, 12:08 PM
Last Post: 11-01-2015, 09:51 PM
By Jpatchley in forum Auto Detailing 101
Last Post: 09-23-2013, 07:59 AM
By Red Lehr in forum Ask your detailing questions!
Last Post: 06-17-2013, 06:57 AM
