Re: Best method for polishing deeply stained single stage paint? Possible mold?
I also want to highlight that I have read your White Paint Lessons article also. Which does give some good insight about the paint but I'm still a bit at a loss of what the best method is.
I guess this is a type II contaminant?
Should I just take my time with a product by hand to make sure I don't create too much heat? Or should I rotary with light pressure and a mild pad?
This paint is definitely very hard. I found that out while sanding down the inside of the tub. Gave my wire wheel a run for its money!
Thanks
Some other photos
Attachment 72936
Attachment 72937
Wheels before and after - some rust around the center lug ring had eaten through all the chrome, so I had to wet sand. It will just live with a wax coating and frequent re-waxing - it's a jeep and they are the original wheels. They look great from 5 feet away.
Attachment 72938
Attachment 72939
Originally Posted by sampsonrustic
Long time reader! But I think my current situation warrants a thread.
Love to see lurkers turn active.
I have a new-to-me 1986 Jeep CJ7 in Olympic White.
What would be the recommended approach to bringing some lift back into this old paint?
Here's one of your pictures...
This is an easy fix. The paint is simply stained. Any quality compound, polish or cleaner/wax will fix this.
I have a DA polisher, access to a variety of pads, and some Megs M83 on-hand.
Here's a question for you...
What do you own for a polisher and pads?
Thanks for the quick response!
And yes it's a great jeep! Bone stock and passed smog! Little 4 cylinder 4-speed but very fun around town and on the milder trails.
I have a new-ish bauer variable speed DA from Harbor Freight.
I was planning to get some new pads because i destroyed (donated) some to my wheel cleaning adventure.
Open to suggestions for product and pads and technique! (start with less abrasive / or more abrasive? good speed for white paint? etc)
Here's another way to skin this cat...
The COMET Technique by Mike Phillips - 1965 Cadillac - Original Single Stage Paint - Slam job by Mike Phillips
The COMET Technique for oxidized single stage paint
NOTE: The COMET technique is ONLY for oxidized SINGLE STAGE paint.
THEN - go to the cleaner/wax step with the DA polisher.
And...
Because you have a rotary polisher - you bet - cut that paint with a wool pad and a quality compound or even the Meguiar's M83 and then FOLLOW with the orbital DA polisher and a good cleaner/wax to remove the holograms and also seal the paint.
And...
Great tips Mike! Thank for your time.
So I have the 8mm orbital DA only - but you are correct it's 6 inch. i will look into finding a 5 inch adapter so I can use some better pads!
The jeep is currently getting some wheel hub, brake, and suspension work done but I will post pictures back in this thread once I attack those stains.
I did remember reading that comet post I will take another read. I think I have some in the garage somewhere.
I'm relieved you think the stains can come out - can't wait to see what this one will look like with some elbow grease.
By muaddba in forum Ask your detailing questions!
Last Post: 10-05-2020, 08:45 AM
By MNRyan in forum Auto Detailing 101
Last Post: 07-12-2017, 07:59 PM
By Bavarian-Cream in forum Ask your detailing questions!
Last Post: 04-05-2013, 11:02 AM
By canairb in forum Auto Detailing 101
Last Post: 08-23-2010, 03:40 PM
