Results 1 to 9 of 9
    Nov 2014
    65
    How to best use deionized water?
    Mike, I recently watched your review of the CR Spotless system and am thinking about incorporating it into my wash system...
    This of you that use deionized water, do you use it for the entire wash process? Is it beneficial when using a foam cannon, filling wash buckets, scrubbing wheels?
    Should I just set up the system and go, or would it be worth the while to set up some sort of filter bypass, so I can use untreated water until say the final rinse?
    Thanks!
    Super Member 57Rambler's Avatar
    May 2019
    Columbus, OH
    1,026
    Re: How to best use deionized water?
    Quote Originally Posted by scv2005 View Post
    ... or would it be worth the while to set up some sort of filter bypass, so I can use untreated water until say the final rinse?
    That's what I would do as it will extend the life of the resin cartridge.
  3. Thanks scv2005 thanked for this post
  4. #3
    Super Member John U's Avatar
    Mar 2006
    Eagan MN & Scottsdale AZ
    665
    Yes, I use it for rinse only.
  5. Thanks scv2005 thanked for this post
  6. #4
    Super Member FUNX650's Avatar
    Dec 2010
    Ohio, USA
    21,057
    •As mentioned above, for the rinse cycle
    Additionally:
    •When manually cleaning fabrics (carpet/
    carpeted mats/seats/etc.)
    •When operating steamers/extractors
    •Since DI water doesn’t contain any “ions”...
    use it when cleaning electronics
  7. Thanks scv2005, Craig Encinitas thanked for this post
    Likes Craig Encinitas liked this post
  8. #5
    Nov 2014
    65
    Thanks everyone! Have a few friends and they insisted they use it for everything, just seems like a waste of resin... Unit is still in transit (DIC-10) but I will grab a quality Y valve ASAP....
  9. #6
    Mar 2019
    The dealership I worked at we used it for entire wash process.
    I have a DI unit (different brand) and I use it the entire wash process. Gentle stream of water for the final rinse from a garden hose to get rid of 80% of water. Forced air dry the large water droplets left. Let the rest evaporate and never any water spots.
  10. Thanks scv2005, Craig Encinitas thanked for this post
  11. #7
    Super Member AutowerxDetailing's Avatar
    Apr 2012
    Sherwood, Oregon
    2,791
    We normally only use DI water for the final rinse or also for water to mix with chemicals. Our Meguiar's Glass cleaner seems to work drastically better when mixed with DI water vs tap water.
    Nicholas Scafidi - CQuartz Finest Authorized Installer
    www.autowerxdetailing.com Auto Detailing in Sherwood, OR
    Like us on Facebook | Follow us on Twitter
  12. Thanks scv2005 thanked for this post
  13. #8
    Nov 2014
    65
    Great idea! I never even thought of the advantages of using it to dilute chemicals!
  14. #9
    It's for the final rinse.
    Also - in the video I shared that the unit comes with a water sprayer that has a SHOWER setting. This is to slow the travel of water through the filters so there is ample amount of time for the resin pellets to extract the nasty stuff out of the water. Too high of a flow of water, for example using the JET setting on a water sprayer and you'll defeat the purpose of the filter.
    For those reading this into the future here's the video and "yes" the black Corvette we washed and then let dry in FULL SUN is the real deal and no water spots.
  15. Thanks scv2005 thanked for this post
  1. Replies: 7
    Last Post: 07-19-2015, 08:54 AM
  2. Replies: 1
    Last Post: 11-14-2014, 08:04 PM
  3. Deionized Water for noobs
    By parkerslade in forum Auto Detailing 101
    Last Post: 04-10-2013, 06:47 PM
  4. Where to get deionized water
    By gofast908z in forum Auto Detailing 101
    Last Post: 04-14-2012, 02:41 PM
  5. Best method for deionized water rinse
    By fishnugget in forum Ask your detailing questions!
    Last Post: 09-17-2010, 05:32 PM
