Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Mar 2020
    33
    Coating and coating sprays
    Is the ceramic spray mostly used as a touch up(after washes) after doing the coating. Thanks in advance
    Super Member WillSports3's Avatar
    Jun 2016
    Toronto, ON
    1,453
    Re: Coating and coating sprays
    You want the long version or the short version?
    2016 Mazda 3 Sports GT
    2015 Lexus IS250 F Sport
    May 2017
    Pittsburgh PA
    2,847
    Part of short story: sure, some are great for touch up after washes, while car is still clean.
    Mar 2020
    33
    Quote Originally Posted by WillSports3 View Post
    Either one just trying to see really what the difference is..I know it's time consuming but it seems the spray will be faster but just unsure if it does a better or equal job that it is supose to
    Aug 2020
    938
    Spray sealants or touchless sealants are the easiest to refresh a coating.
    Super Member The Guz's Avatar
    Jun 2013
    LA, CA
    8,719
    Quote Originally Posted by Blacklightn25 View Post
    The abundance of silica spray sealants are easy to apply but won't match the performance or longevity of a true resin based coating. That is the short answer.
    Jun 2016
    Toronto, ON
    1,453
    Short answer on my part. There wre only about three or four products that are made and designed to be true coating toppers. Everything else is just siloxane and PDMS products that have nothing really to do with prolonging coatings.
    Dec 2018
    7,240
    What are rhe 3-4 true toppers?
    Jun 2016
    Toronto, ON
    1,453
    Tried to PM you says your inbox is full.
  10. #10
    I agree with all the above.
    The true coatings come in tiny glass bottles that lock out oxygen so the liquid won't dry hard.
    Installing a true coating is a lot of work - mostly in all the prep work,
    1. Wash and dry car
    2. Clay paint
    3. Correct paint - compound and polish
    4. Chemically strip paint
    After all of the above - NOW you can INSTALL a coating. The word install simply means "apply". Our industry is silly.
    The above all said - the simple spray-on types are faster and are easier and you could simply,
    1. Wash and dry
    2. Clay if needed
    3. Spray-on, spread-around and then wipe-off any excess
    And the end results will be - water will bead up like crazy and that's the main "appearance" criteria everyone uses to judge a coating. How LONG the water beads up in tight, tiny water beads is the other criteria called,
    Longevity
    In my opinion - the best way to actually seal and protect your car's paint is the long way, machine polishing but heck - if you don't care about removing swirls - a coating will stick to paint that has swirls and scratches.
  1. Replies: 38
    Last Post: 10-09-2017, 07:55 AM
  2. Replies: 6
    Last Post: 08-21-2017, 09:27 AM
  3. Replies: 11
    Last Post: 08-09-2016, 09:29 AM
  4. Replies: 2
    Last Post: 11-08-2013, 04:09 PM
  5. Replies: 7
    Last Post: 11-03-2013, 06:34 AM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
