Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
  1. #1
    Junior Member
    Join Date
    Oct 2011
    Posts
    63
    Post Thanks / Like
    Can we cut the SiO2 coating nonsense out?
    I want to take a trip down memory lane for a moment to explain what I am asking.... A while back I had asked about Iron X...... A great product, but fairly pricey and the knock off products tend to be pricey also, mainly because of the top secret active ingredients that actually de-contaminate the iron from surfaces that is soo crazy expensive.
    So SiO2 is the latest crazy and all the companies need to have their own version of an Si02 coating with lifespans anywhere frrom 6 months for really "cheap" stuff to 7-9 years for the really expensive stuff. What I want to know is if there is a scientific guide meaning..... how much Si02 per ml or oz or how everr it needs to be measured, is suitable for a specific duration or longevity of the product.
    We need something like an independent testing lab for non-bias results. Do you get the knock off products off Amazon @ $20 a bottle or the $400 per bottle stuff that contains "magical" Si02 in it that lasts 9 years? Does it really last that long? And what about doing a coating of Si02, Waiting a month for it to cure and then applying a second coat? I am not looking for .....yeah it lasts longer. I want solid proof. Is the $49 bottle of Si02 as good as the $200 bottle? I'm not looking for company reps to throw sales pitches out. Prove it.
    And come on.... there are probably 2 or maybe 3 companies that make Si02 world wide........ so some of the prices and advertisements are kind of funny.... it is all the same stuff re-branded.... or at least a few versions of the same stuff re-branded.
  2. Thanks Craig Encinitas thanked for this post
    Likes tomsteve, Craig Encinitas liked this post
  3. #2
    Super Member Calendyr's Avatar
    Join Date
    Jun 2013
    Location
    Montreal, Quebec
    Posts
    3,996
    Post Thanks / Like
    Re: Can we cut the SiO2 coating nonsense out?
    There are independant tests being run. Check youtube, this guy is on his third durability test. YouTube
    The cheap stuff fared extremelly poorly. The stuff they sell on ebay doesn't even last as long as a sealant. The 2 years products seems to have durability ranging from 1 to 2 years so far.
    The 5 years products have not yet failed after over 2 years as far as I know.
    You do get what you pay for with these products. I think that 5 years products are the sweet spot. At some point you will want to polish the paint to remove micro scratches, and that process removes the coating. And I don't think you will want to wait 9 years to do this.
  4. #3
    Super Member
    Join Date
    Sep 2017
    Location
    Sweden
    Posts
    3,022
    Post Thanks / Like
    I have no proof of what you asking and maybe only a chemist in the industry may have the answer for you.
    What I have understand from SiO2 is that's it's not so much of the SiO2 it self. But how you blend it with other chemicals such as carrier and other chemicals that makes the SiO2 part behave differently. A pure SiO2 layer won't be doing much on the paint. It's the reaction it has when applyied with the other chemicals in it. SiO2 on it self is not extremly hydrophobic or slick to the touch. So they mix it with another chemical to create a hydrophobic top layer and base layer when it's cures on the paint. And that's on molecules level this happens and atoms is released from the liquid and added by the air molecules to form a special behavior.
    Then it's not only SiO2 based ceramic coatings out there. You have organic coatings and most that says nano coating is often not based on the SiO2 build up of protection.
    The description of the amount of SiO2 in a bottle is pretty much useless to transfer to longevity from it on the paint. WOW 10% SiO2 in it than the more common 5% in SiO2 sealants. That's must get you the double longevity from it. Wrong. Look at the Polish Angel Rapidwaxx or Cosmic Spritz or Viking Spritz or High Gloss or even the QD Sprayduster. All of them have an amount of over 25% SiO2 at least in them. And they don't last as long as Gyeon CanCoat with 20-25% IIRC. In the chemical mix of PA products it's more like a little bit of product goes a long way with them. High Gloss has a wopping 85% of TiO2 in it and 5% SiO2 and is for maintance every month or every other month. As is the others too maintance in first place for PA different protection products. But can be used on their own. Then it's much about how you measure longevity. Is it how long you have a great behavior and protection from it or is it when it has worn off completly. This can also differs from brands but the later is what's useally noticed and claims.
    I just think this is how these products is marketed to people. And pretty much every product claims it's the best product in it's range. Even from 2 products from the same brand and same range I have seen this LOL. That don't necessary says the products is bad in any way. It's just how marketing works and some make bold and untrue claims and some just hype up the product a little extra than it is. You don't see a product claim it's low quality and in the bottom of effectiveness in it's range. Some and very few just describes what you get from the product with no comparison with other products.
    The SiO2 market is not black and white but has a wide range cause of the different uses and mixes. And it's not even a new thing either but have been used a long time as a base chemical in different kind of products. Also it's used widely in other industries as well as in medical products and food products and metall industry. So absolutely SiO2 is hyped in many cases but that don't make it bad products to use. I just notice that's based or have it in the product and then see how the product actually works for me.
    And to do an iron removal on your paint you don't need to be useing a color changing iron remover. Acid based iron removers works as good as well. Just that you need to be casious to let get on the headlights and glass. So the color changing iron remover is a safer use and you can use it on most materials you have on the car. Not all though as it can stain some materials and even some paints as single stage paints. There it could even be a benefit with the iron removal with an acid based one as it's alse good to desolve oxidized paint too. Oxalic acid in powder form and dilute it 1:32 with distilled water and you have a very economical iron remover that you spray on.
  5. Thanks Craig Encinitas thanked for this post
  6. #4
    Super Member FUNX650's Avatar
    Join Date
    Dec 2010
    Location
    Ohio, USA
    Posts
    21,057
    Post Thanks / Like
    •IMO:
    -One quick way to “cut the SiO2 coating
    nonsense out” is to go back to calling
    them by what they are comprised of;
    and/or, have been marketed as:
    -Silicon (not silicone), Silica, Silicon Dioxide,
    Quartz, Glass, Nano(es), Ceramics, etc.—all
    interchangeable marketing terms—comes to mind.
    In other words:
    Why not add some more nonsense...
    •And let’s not forget the SiC Coatings category:
    Pre-polymer, polymers, epoxy, etc.
    [Oh yeah, (lest I be accused of being somewhat
    lackadaisical) since I mentioned polymers:
    Resins anyone?]
    "Be wary of the man who urges an action in which he himself incurs no risk."
    ~Joaquin de Setanti
  7. Thanks Craig Encinitas thanked for this post
    Likes Craig Encinitas liked this post
  8. #5
    Mike Phillips
    Guest
    Quote Originally Posted by Calendyr View Post
    Thanks for sharing the above.
  9. Likes Calendyr liked this post
  10. #6
    Mike Phillips
    Guest
    Quote Originally Posted by nakranij View Post
    Completely understand your sentiment but there's a LOT of great SiO2 products out there>. Here's just one of my favorites. I use this on my personal cars. I've sent out dozens of FREE samples because I think it's so good and the feedback I get is always positive.
    KILLER CAR WASH - Wolfgang Uber SiO2 Coating Wash
    Here's my recommendation, because you're never going to get people do do what you want, do this instead,
    Find something YOU like and use it often
  11. Likes SWETM, acuRAS82, Icarus liked this post
  12. #7
    Super Member Dereksdtail's Avatar
    Join Date
    Jul 2014
    Posts
    1,252
    Post Thanks / Like
    Coatings could be a little bit of nonsense but since I’ve been having more people want them on their cars, I have found the process of prepping and applying the coating is fun and rewarding, they might not last as long as they say but when you pull the car out of the shop/garage it’s pretty special
  13. Likes Goonie75, Coatingsarecrack liked this post
  14. #8
    Super Member Coatingsarecrack's Avatar
    Join Date
    Dec 2018
    Posts
    7,177
    Post Thanks / Like
    Quote Originally Posted by Dereksdtail View Post
    When I pulled my cquk3.0 coated car out of garage could not stop staring...
  15. Thanks Craig Encinitas thanked for this post
    Likes Dereksdtail, Craig Encinitas liked this post
  16. #9
    Super Member Mgavin1985's Avatar
    Join Date
    Nov 2017
    Posts
    497
    Post Thanks / Like
    A glass of SIO2 a day keeps the doctor away..
  17. #10
    Mike Phillips
    Guest
    I find the process longer and it also means bringing up your level of CARE as you chemically strip and then coat the car. This would also be after ALL the other steps, washing, claying, compounding and polishing, that's a lot of time and labor/energy. And if you get tired or are not careful when chemically stripping the paint you could put scratches back into the paint.
    That said, here's a car I coated last Friday. These pictures taken with my Canon T6i
    She came in dirty and contaminated, filled with light swirls and scratches everywhere.
    She left looking like a liquid wet, polished gemstone.
    Paint sealed with Pinnacle Black Label Diamond Paint Coating
    I think the results speak for the product....
    All work performed using products from Pinnacle Black Label. The tool I used is the NEW CBEAST by FLEX.
    Pads: I tested 3 different pads, the pads I went with were the B&S Uro-Tech 6" Dark Blue Heavy Polishing Foam Pad
    The term I used to describe the results from a proper coating install is
    GLASSY
    Glassy is like a tick higher than glossy.
  18. Thanks Craig Encinitas thanked for this post
Similar Threads
  1. Dealership messed up sio2 coating I think?
    By laramik in forum Ask your detailing questions!
    Last Post: 05-17-2019, 07:20 PM
  2. SIO2 Coating Maintenance
    By bfenne in forum Auto Detailing 101
    Last Post: 06-29-2018, 01:21 PM
  3. SIO2 Spray Coating Help
    By bfenne in forum Ask your detailing questions!
    Last Post: 04-06-2018, 04:49 AM
  4. McKee's 37 Paint Coating Sio2 Nano Coating
    By luckydawg in forum Ask your detailing questions!
    Last Post: 04-02-2018, 02:27 PM
  5. Replies: 51
    Last Post: 06-12-2017, 08:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
» April 2024
S M T W T F S
31 1 2 3 4 5 6
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30 1234
