Results 1 to 4 of 4
    Need help removing orange peel?
    I found a new member asking questions in the Chatbox. I kindly let him know he was in the Chatbox. The Chatbox is for small talk. To have a real conversation a person wants to "Start a thread".
    He said he was going to take the conversation to the forum but I never saw anything pop up? So I'm starting this for him...
    From the Chatbox
    Quote Originally Posted by Ando94
    I tried these new lake foam pads on my 3401 and can’t seem to remove orange peel I’m using with cg 32 and geon compound + no luck
    Hi Ando94,
    You can't really remove orange peel from car paint via buffing. I have a picture from the early 1990's where I DID remove orange peel by only buffing but it's a LOT of hard work and really not the way to do it.
    Damn.... I think I have an article on everything....
    Can orange peel be removed or lessoned by just machine compounding?
    Here's with a Porter Cable and CarPro Denim Pads
    How to remove Orange Peel using a Porter Cable Dual Action Polisher
    My preferred method is a technique I call Scuff and Buff and I teach it in some of my classes.
    Re: Need help removing orange peel?
    Question....
    What are you working on?
    Feb 2019
    Hey mike
    I’m currently working on some upgrades that I purchased for my 2018!Fk8 Civic. Type R
    and well I’m not a professional painter by all means and I’ve watched and tried to understand as much as possible, with that being sad I purchased the flex 3403 to use since my Da (Flex3401) just didn’t seem to get it done.
    However I seen you guys use it and it does phenomenal I’ve tried the microfiber pads I’ve tried a few compounds no luck so I ordered the Meguiars kit and I’m hoping that’ll do the job I wish I would of knew the 3493 wasn’t that great for cars I just liked how I can go from a 1in to 7in pad that compared with the e peices i thought it’d be a smooth set up I just need to get a wall rack lot keep the machines from laying around
    Question....
    So did you paint this car or are you working on the factory clear coat?
  1. Q's about removing orange peel.
    By eyost in forum Auto Detailing 101
    Last Post: 02-24-2020, 06:06 PM
  2. Removing heavy orange peel - Denim Pad failed
    By rs4imola in forum Ask your detailing questions!
    Last Post: 02-28-2019, 12:05 PM
  3. Removing the Orange Peel with many Details
    By stilltipping3 in forum Ask your detailing questions!
    Last Post: 10-03-2013, 05:34 PM
  4. Removing Orange Peel Before Clear Coating?
    By Marty in forum Ask your detailing questions!
    Last Post: 09-03-2013, 07:08 AM
  5. Replies: 32
    Last Post: 05-16-2013, 12:47 PM
