Polish aluminium rocker panels
Hi, new to the forum. Lot of good info here, This has probably been asked Before. I´ve been wet sanding with 2000 grit then 2500. Polished with Mothers mag and alu polish with Mothers Power ball. Can´t get rid of the sanding marks. Do i use to slow or high rpms on my cordless power drill maybe? Maybe should polish for a longer time? More sanding with even finer grit?
Best regards Björn
If the Mag Polish isn’t cutting it, you’re going to need to step up to a more aggressive metal polish to remove your sanding marks. Maybe try something like this Mothers Power Metal + a finer grit sandpaper.
Mothers PowerMetal Scratch Removing Polish, metal polish, remove metal scratches
Re: Polish aluminium rocker panels
I personally go to 5k grit. I polish turbo covers and backing plates by hand and refine from 800 up to 5k. Then I polish to a mirror
Sent from my SM-G930V using Tapatalk
Thanks for a Quick respond. Gonna see if I can get hold of it here in Sweden.
Best regards Björn
Originally Posted by
redkenyan
Best regards Björn
Välkommen till forumet
Is there anything I can help you with to find what you need. Just send a PM and I can help with links.
/ Tony
