Results 1 to 10 of 10
    Dec 2017
    481
    Stone chip repair
    Hi I have tried to brush in chips but I gave overfilled though smooth they are high. I don't have a powered polisher. Please can someone advise what to do. It is black and is the bonnet and has been buffed twice. Thanks in advance.
    Super Member Rsurfer's Avatar
    Jan 2007
    14,097
    Re: Stone chip repair
    Quote Originally Posted by PeteT19640 View Post
    Do you or don't you have a buffer?
    Dec 2017
    481
    No i don't
    Jan 2007
    14,097
    No i don't
    You will need to wet sand to level the fill and then buff out the sanding scratches.
    Dec 2017
    481
    Thank you
    What grit would you recommend?
    Would it best to feather out?
    Jan 2007
    14,097
    Thank you
    Depending on how high the fill is. Start with 1000-1500 then 2000 and finish with 3000.
    You need to be very careful around the edges of the fill and not over sand the surrounding paint.
    If the chip is small, you can use a sanding pen which will allow you to pin point the sanding and not over sand the edges.
    Buff out and your done..easier said than done.
    Jun 2013
    Montreal, Quebec
    3,996
    A safer way would be to use a razor blade to get the excess paint off from the repair. Then you can do a light sanding and polishing. Trying to sand a paint chip repair is very risky. It's increadibly easy to cut through the surrounding paint and I would not recommend you try.
    Dec 2017
    481
    Thank you
    Is there a particular way of doing this and also blade?
    Jan 2007
    14,097
    Thank you
    Carefully!!
  10. #10
    Jun 2013
    Montreal, Quebec
    3,996
    Thank you
    Hum... I cannot recall where I saw the technique. What I can tell you is that it was a video on youtube. Try searching for paint chip repair and razor blade. I am sure you can find a few videos showing how to do it correctly.
  1. Window care - sealant/wax? Stone chip repair?
    By 82DMC12 in forum Auto Detailing 101
    Last Post: 10-14-2019, 09:48 PM
  2. stone chip repair
    By One2nine in forum Ask your detailing questions!
    Last Post: 03-07-2014, 12:56 AM
  3. Stone chip repair
    By cheekyage in forum Auto Detailing 101
    Last Post: 10-27-2013, 05:22 PM
  4. Stone Chip
    By excalibur in forum Auto Detailing 101
    Last Post: 06-28-2012, 04:56 PM
  5. How to get rid of stone chip with rust
    By tktlau in forum Auto Detailing 101
    Last Post: 03-18-2010, 03:14 PM
