Wax on wax off
This is my first post here I really hope someone can guide me in the right direction, I’ve searched YouTube (probably not using the right words) and can’t find anyone addressing the issue I’m having. So,,, I just bought my dream car, after owning several mustangs and a couple years of searching I now have a 2012 Shelby GT500 with only 5450 miles on it ,,I’m trying to get the wax off the edges of the mat black vinyl stripes I was able to get the surface of the stripes completely clean but I’m afraid to try anything without seeking some advice for fear I will damage the vinyl and/or the Adhesive.
Thanks Eric Manning
Re: Wax on wax off
Hey Eric, Welcome to the forum. As a GT350 owner, this is how I tackled the stripe situation.
Post Thanks / Like - 1 Thanks, 5 Likes, 0 Dislikes
Re: Wax on wax off
Lol. Very helpful suggestion!
You can try some clay, but a little Dawn should clean you right up.
Congrats on the GT500!
Re: Wax on wax off
have you tried a medium to hard tooth brush with some APC ??
Re: Wax on wax off
Use a detailing brush like this 1 w/some detail spray or diluted APC and gently agitate along the edges and it should come clean.
If for some reason that doesn’t work [I can’t imagine it wouldn’t] you can try using a bamboo skewer, but you better be careful.
Re: Wax on wax off
Clay tends to get stuck inside tiny cracks & crevices, so it would more than likely add to the problem.
Re: Wax on wax off
Hello, and welcome to the Forum!
You might get many suggestions from some of the members here. Some may be sound methods of cleaning, but here's my take.
That this has been the bane of many wipe on wipe off waxes and sealants for donkey's years. How to then get to residues out of the cracks, crevices, around and within Badges, Seams, etc.
I know well from experience that any sort of physical rubbing, or the use of tools like Detailing Brushes, Toothbrushes, or harsh cleaners and scrubs will more than likely cause marring, scratching of the paint and damage to the Decals as well.
That leaves another method then, some other form of chemical removal. But what?
The theme will be to use something as gentle as possible, and to use gentle physical means.
Now some might say a prep cleaning agent, maybe something like Carpro Eraser, which is a gentle diluted Alcohol base cleaner used to prep surfaces prior to applying Ceramic Coatings. This might work without causing any damage to paint or decals.
What I myself might be more inclined to try, would be what we folks here call a WOWA Sealant (Wipe On Walk Away). These products are generally crystal clear fluids which contain polymers, but contain no abrasives or detergent cleaners, they leave basically no residues behind after use. I've come to love many of these types of products for their ease of use in areas where the wipe on wipe off products prove problematic, like Door Jambs, Trunk and inside Hood detailing, and any other areas that might prove difficult with cruds left behind.
I am maybe thinking to perhaps use with a new small applicator pad, either Microfiber, or Foam, and to let the carrier solvents in these relatively safe to decals products gently dissolve and remove these residues you experience.
I myself would rather try this first, than go to a more harsher method or product.
Such products I might suggest would be Ultima Paint Guard Plus, Optimum Opti-Seal. There's probably some others I'm forgetting.
If I'm wrong with such suggestions, then other members please correct me.
For sure, these two I mention above will not scratch or damage the paint or decals.
Re: Wax on wax off
I've had luck with the Mother's Speedclay. Helped me take off wax and latex paint on a customer's truck.
Sent from my SM-N950U using Autogeekonline mobile app
Re: Wax on wax off
A toothpick works great for getting old dried wax from the edges of stripes or other decal/films... And it won't cause scratches and/or marring to the surrounding paint like a brush will.
Re: Wax on wax off
•I like using “Dried-on Wax Removers”;
-the ones from Griot’s Garage, and
McKee’s 37, to be more specific.
