Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Sep 2015
    6,281
    Re: Unkown speckles on black paint
    Quote Originally Posted by vertico View Post
    Awesome, great ideas Unkown speckles on black paint
    So in order i'm going to try:
    IronX
    Nanoskin fine-medium towel
    Nanoskin fine DA pad
    Are mineral spirits safe for the paint? Sounds too harsh no?
    I've got everything on order. After xmas is over i'm going to go to town on it.
    I'll post up my results when done!
    While i'm at it i'll try to get a before pic of the swirls that are there. This paint is amazingly deceiving for black paint, under most light it looks super glossy but when the sun hits it JUST right it's swirl city. Previous owner clearly ran it through automatic washers.
    OT but on a side note the interior is in great condition as well except the center console is made of gloss piano black plastic that shows a ton of swirls. I picked up a 3" backplate for a drill that i'm going to try to use to polish it back to normal. It's crazy how badly scratched it is! I can see finger nail marks from people adjusting the volume on the radio
    Once i get these two things fixed up the car will be in near perfect condition!
    It's a weekend warrior only so it will live in my garage 99% of the time
    clearcoats can tolerate mineral spirits lacquer thinner and xylene.If that was my car I would get some lacquer thinner and one swipe it should come off.But that's me try the mineral spirits as suggested.
  2. #22
    Sep 2015
    6,281
    I would get that off now.waiting after Christmas you may get the heads off of whatever is on there but may struggle with the residual staining of each little dot.
  3. #23
    Sep 2015
    6,281
    IronX
    i would do by hand first 3 inch maybe to big.mags plastic polish or followed by some carpro essence maybe favorable.Essence you should buy anyway along with the carpro gloss pad for that paint.
  4. #24
    Sep 2015
    6,281
    I meant meguairs plastic polish not mags.
  5. #25
    Super Member Crispy's Avatar
    Jun 2013
    779
    I have removed similar spots upon return from body shop where I had a panel sprayed.
    It was clear coat over spray, so you only see it from certain angles and lighting.
    I did the baggy test to confirm, and yes there was more than I thought.
    Took the Speedy Prep Towel to her and it was removing much of it, but slowly.
    Tried the Real Mineral Spirits and Plastic Razor Blade (I too could get it off with fingernail, but razor better) and worked much better.
    Speedy Prep Towel and Clay Lube over affected panels, baggy test and then Polished (no compounding).
    Worked for me.
  1. What are those speckles/pinholes on my paint surface
    By chenghe830 in forum Auto Detailing 101
    Last Post: 11-19-2020, 05:05 PM
  2. Polish caused white speckles in black paint!?
    By Pete7 in forum Auto Detailing 101
    Last Post: 12-21-2015, 08:35 PM
  3. Speckles still on car after wash
    By GerGa in forum Auto Detailing 101
    Last Post: 08-25-2013, 08:42 PM
  4. Speckles on paint
    By ThirdgenTa in forum Auto Detailing 101
    Last Post: 11-01-2011, 09:18 AM
  5. Car Wax Gel/Liquid from early 1990's Unkown Brand
    By Machnumber2 in forum Off-Topic
    Last Post: 07-27-2009, 11:43 PM
» June 2024
262728293031 1
2 3 4 5 6 7 8
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
30 123456
