Having trouble polishing out swirl marks - Griots Garage 3 Inch Orbital Polisher + Menzerna Heavy Cut Compound 1000
Hi, to start, this is not an auto project. Rather, I've been using automotive clear coat on wood surfaces for final finish. Process is:
1) HVLP spray clear coat (I've used a Nason product and something called TRUE clear)
2) Sand to flat (meaning remove any wood grain, pores, or other non-flat features )
3) Spray coat of same clear coat (mostly to ensure I don't sand through / burn through)
4) Sand starting with 1500 up to 2000 (remove orange peel with 1500, just remove sanding marks with 2000)
5) Apply Menzerna Heavy Cut Compound 1000, polish using Griots Garage 3 Inch Orbital Polisher at speed setting 6 most of the time
6) Apply Menzerna FF 3000, polish using Griots Garage 3 Inch Orbital Polisher (different foam pad!), speed setting 4-5
Final surface is beautiful in most lights, and has a nice "wet" look. Only when I put it under very bright LED light will I spot the circular swirlies, left by the orbital (my assumption is this is from step 5). I've tried many times now, and many different techniques, pressure levels, times at Max Speed, etc. but nothing really makes much difference. I've also tried different amounts of the HCC 1000, from a very light amount to almost a glaze (the latter splatters everywhere, I'm sure you all knew that would happen).
The surfaces I'm polishing are not very large - coffee table at most, and I'm happy to experiment as needed to make this perfect.
Any thoughts? Thanks!
Re: Having trouble polishing out swirl marks - Griots Garage 3 Inch Orbital Polisher + Menzerna Heavy Cut Compound 1000
The power behind the 3" GG may not be enough to remove the swirls. It's a rather lacking machine for correcting.
Ah shoot - I was kinda wondering if that might be the issue. Any idea how best to test that idea? I guess a test of the same clear coat, same process, but a proven polisher would be good -- I just don't have any friends who do this kind of work, or else I'd be bugging them right now!
Any specific 3" tool that you'd recommend as reliable in this area?
Too bad if that's the case, given the "Remove Swirls" line in thier product headline, but maybe I'm not totally understanding.
Griots Garage 3 Inch Orbital Polisher, 3 Inch Polisher, 3 inch Dual Action Polisher, 3" buffer
As mentioned, the 3" lacks power. Get a Griot 6" and a 3.5" backing plate. Now you can run 6" pads on larger surfaces and 4" pads on smaller areas.
I prefer Menzerna polishes, but if on a budget, Meg's Ultimate Compound and Polish will do.
Slow arm movement (1" per second) with 15lbs. of pressure is the key to getting outstanding results.
Hey OP,
What pads are you using with the machine? The Griots 3" machine definitely lacks power compare to other smaller machines. However; check out this article that Mike Phillips wrote about some new pads that make that machine a bit better:
http://www.autogeekonline.net/forum/...foam-pads.html
Since you are using a 3" setup, I am assuming you're not working on a huge surface. My recommendation would possible be a rotary with 3" setup for cutting and then finishing with your current machine.
Carolina`s Finest Detailing - Charlotte areas preferred CQuartz Finest Reserve & GTECHNIQ Crystal Serum Ultra coating center. STEK/Suntek PPF
www.Carolinasfinestdetailing.me
Any specific 3" tool that you'd recommend as reliable in this area? If your willing to spend the bucks (3+bills), get the Rupes Mini Polisher.
Thanks again:
-- I'll look to see if I can borrow a 6" from somewhere, and test against my setup. If it "just works," then I'll switch machines (a bit disappointing, as I'm not sure what the GG is for, exactly, then, but OK)
BUT... hope I don't seem like I'm ignoring these tips...
I'd like to try those thinner foam pads, based on that article you linked. I've only used the thick ones that came with the GG 3".
To clarify, should I use the ORANGE pad with the HCC 1000, then WHITE with FF 3000?
Thanks again you all!
EDIT: I just went ahead and ordered a six-pack of those thin-pro pads - 1 grey, 2 orange, and 3 white. We'll see - happy to report results if folks care!
Definitely the polisher, pretty useless really. I actually use Metabo rotary right angle grinder on slowest speed with 1" or 2" pads. Does pretty good.
Last Post: 08-20-2018, 08:23 AM
By mwoywod in forum Auto Detailing 101
Last Post: 11-05-2016, 08:33 AM
By Johny B in forum Ask your detailing questions!
Last Post: 07-27-2012, 06:36 PM
By Louie_Blu in forum Ask your detailing questions!
Last Post: 02-22-2012, 09:26 PM
By jlharrl in forum Auto Detailing 101
Last Post: 09-02-2006, 10:20 AM
