Re: Denim and compound too slow... Next step up??
Thanks all....
My plan of using old style non diminishing Deffo helps...
Mike your guess proves correct, it works longer and importantly for feel runs consistently as the pads loads up.. The DAT cuts and runs smoothly then drops off as the pads loads up and the feel changes...
I have found the consistent feel helps with smoother passes and hence a more consistent level of removal..
Just finished the front wing... Hardest bit is conforming to the panel profile
With such a firm pad face. Plenty of styling it with the rotary... And judicious use of the 3" pads...
Thanks again for the suggestions it's been a great learning journey with great results as well..
Just hard yakka....
I had a panel repainted and used CarPro denim pads with Meg's M105 and a Flex 3401 to knock out some of the orange peel. I worked the panel (bottom half of a door, E46 BMW vert) for 5 minutes max and there was already noticeable improvement, to the point where I decided to back off because I started to worry about clear coat thickness. It finished out well, I just left it as is because on another day I knew I was going to hit everything with M205. I don't recall the speed I was working at, but it was probably 80% of WOT because I rarely go max speed. So I'm absolutely baffled that you worked a panel for three hours with minimal results. And it seems like you are using good products. I can only think you must have some incredibly hard clear coat.
Huge difference between shop paint on a door lower and bloody Merc white single stage factory paint... It seems 😳
lit is "resilient" that's for sure...
Also the panel form means a lot of careful polisher work (convex / concave), not just ploughing through it...
cleaning the pads after every pass is also time consuming..... But yeah it's safe and it's getting results...
I'm looking forward to the hood cos it's a flat canvas relative to the side of this car..
we'll get there.... 👍🏻
Originally Posted by shadwell
No idea re paint thickness... As this process is so very slow and I check the condition after every pass I am removing 90% of the crest of the peel... It's bugger all... Knowing my luck some clown will smack into me a week after I'm done anyway.....
Ya, his name is Murphy and he is an a hole
Looks like tedious work, Shadwell, but the difference in pics 2 and 3 above are significant!
Single stage white.. "no clear here.."
Too bad you didn't say it was single stage at the start. Could have saved you days of work. Mike has a great article about restoring single stage paints and it works for him.
Hi mike,
Have been working to reduce the orange peel on
My 2015 c class, polar white, single stage...
Last Post: 04-30-2020, 09:53 AM
By mwoywod in forum Auto Detailing 101
Last Post: 09-03-2017, 09:39 AM
By dcjredline in forum Product Reviews
Last Post: 11-04-2015, 12:39 PM
By Matt@Revive in forum Products Guides
Last Post: 07-16-2015, 08:53 AM
By Chrono in forum Porter Cable 7424XP Dual Action Orbital Polisher
Last Post: 04-23-2014, 10:25 PM
