Yellow pad to white pad
Was wondering if anyone sees an issue with doing m105 with a yellow pad than right to white with m205. I'm working on a very heavily swirled out black impreza and was thinking this route would be good based on the amount of time I have with the car. Thanks in advance...
Re: Yellow pad to white pad
Oh they're lake country foam pads
Should be alright. Someone with a little more experience will probably chime in too. But I don't really see an issue beings that 205 is usually used with a white or grey pad. The yellow shouldn't make it too bad that the white wont clean it up enough.
Sounds like a logical progression.
Remember that first, in order to use the yellow you would have done a test spot to find out it you actually *needed* the yellow, (over white or orange). After the compounding is done about the most cut I'd ever consider with a polish would be the white pad. Remember that when using it you can do your first few section passes with more pressure, then it's possible to do a few of the end passes with the same pad but very light pressure and it'll finish out pretty nicely.
Thanks guys...I def do a test spot but most of you have done hundreds or even thousands of cars to my 50 or so...thanks again
Make sure you prove you can remove the marring that the yellow pad will add with M105. It may be easier to just M105 on two passes with an orange pad.
I really don't have too much experience but do have a black WRX and yellow pad with 105 seems like a HEAVY combo for soft Subaru paint.
Like the other poster said you might do well doing a test spot with a lighter pad and compound/polish combo first to make sure that 105 and yellow is really needed. Good Luck!
2003 Midnight Black Pearl WRX (Cobb AP stg 2) - Daily
1993 Vintage Red RX-7 Twin Turbo (stock, 18,500 miles) - Sunday
~Drew
Thanks ill get some pics up later.. I got it washed clayed prepped for tomorrow. Paint is def in rough shape though. But ill try orange first, hopefully that is enough..
By Bryan@AzDPC.com in forum RUPES BigFoot Oribital Polishers
Last Post: 07-30-2017, 06:32 PM
By ichigo103 in forum Ask your detailing questions!
Last Post: 03-25-2016, 04:13 PM
By Mike Calloway in forum Auto Detailing 101
Last Post: 06-09-2015, 06:52 PM
By clm65 in forum Auto Detailing 101
Last Post: 04-30-2011, 12:17 PM
By Jmunk in forum Off-Topic
Last Post: 06-13-2007, 08:02 PM
