Rotary vs Dual Action
Ok, Now I know the mechanical differences between the two. Ive been using an old Vector Rotary for a while now. it has never failed me, and does a great job. but its a bulky, heavy machine. Im using 8.5" pads on it. it works great for just about everything (except those hard to reach places)
Everyone always talks about the benefit of the DA being its easier for the less experienced user. I am wondering is it worth picking up a PC DA or other model to add to my collection. Would it be better suited for applying those final stages of cleaners and waxes then firing up my rotary?
my main question is. can a DA make my life easier? my rotary is a monster and i dont mind using it. its of those "if its not broken dont fix it" situations. I am just wondering if it will allow me to work faster and more efficiently then using a rotary for finishing. Obviously for scratch and oxidation removal ill use my rotary because of the power. Also for any wet sanding correction. Is there any downsides to using a rotary from start to finish? Can it leave swirls that I am not seeing until weeks after the waxes break down and wear off? Does the increased heat
im basically looking for all the pros and cons of the two. aside from the fact that its easier to use for less experienced users. Ive never done anything to a car with my rotary. I dont plan to start. Although i know anything can happen.
I just cant decide do I buy the PC DA intro pad kit or do i just get some more pads for my rotary and some other little things i need and just move on. Im having a hard time springing for the DA since Ive had nothing but great results from my rotary
Thanks guys.
Re: Rotary vs Dual Action
You won't see holograms weeks later with a DA. More detailers are hanging up their rotaries and going with a DA with the new polishes (105/205, Optimum Hyper Spray).
I just made the move to pick up a DA, and i've used it 1 time so far. So far I feel like the rotary is a great tool for getting the hard stuff out of the way quickly. You can get rid of the deeper stuff with the rotary and if using the right pads/products the finish will look great when you are done, but most the time you look over the car there are a few holograms and swirls left over. By incorporating a DA, you can finish out what you have done with the rotary to perfection without the worry of holograms and swirls. Wax application is also very simple with a DA, you put it on the pad, flip a switch and just let the DA glide across the paint. Very simple.
Cons of each are pretty easy; the rotary is difficult to finish perfect with and tends to leave holograms somewhere. The DA is not as powerful and will not be able to get rid of the deepest stuff or wetsanding marks as easily.
By combining both in your detailing, you will see better results and be able to work faster. Start with the rotary, end with the DA.
Jon Miles
thanks, guys thats what i was sort of thinking but for the value i couldnt decide whether or not i should make the move or pick up some other things.
Actually, if you detail cars all the time or even occasionally you should have one of each, rotary buffers are the best tool for the job for some procedures while DA Polishers are best for other jobs...
If you don't have a DA Polisher then definitely add one to your arsenal...
I posted the below to another thread yesterday but it pretty much fits here too...
We used 2 PC's last night to turn a diamond in the ruff into a glistening gemstone...
No swirls, no burn-throughs, just pure clear shine...
Here's an article I wrote where I created a "Ease of Use Scale" and rated all the popular machine. There's two videos below it where you can see all of the different types turned on and operated...
Here's an in-depth article on the topic...
How to choose the right polisher for your detailing project
An overview with demonstrations of the Porter Cable 7424XP, Meguiar's G110v2, Griot's Garage 6" Random Orbital Polisher, Griot's Garage 3" Mini Polisher, Flex 3401, Flex 603, Flex 3403, Cyclo Polisher, Makita 9227C, DeWalt 849,
Part 1 - How To Pick the Right Car Polisher for your Detail Project [ame=http://www.youtube.com/watch?v=LtrdTvnZX3I]YouTube - Part 1 - How To Pick the Right Car Polisher for your Detail Project[/video]
Part 2 - How To Pick the Right Car Polisher for your Detail Project [ame=http://www.youtube.com/watch?v=2k92m5cJxCk]YouTube - Part 2 - How To Pick the Right Car Polisher for your Detail Project[/video]
The Flex 3401 in action... [ame=http://www.youtube.com/watch?v=3CtUaI_8HhE]YouTube - Performing a "Test Spot" to the paint on a 1957 Chevrolet Belair[/video]
How much time will really be saved? I know using the rotary is obviously faster. When you follow it up with a DA how long will you have to polish to remove the light swirls etc. left by the rotary? It's not correction but what would be involved in the final step with the DA and what type of product would you be using?
You would normally only need to use a medium to light cut polish with a polishing pad.
What you need depends upon how deep the swirls are and how hard the paint is... removing swirls is simply a leveling process.
Ive had great success on most paint using the DA with M205 with about 3 passes to get rid of holograms if my rotary leaves some behind. Its a relatively quick process. The menzerna finishing polishes work really well too but you might have to work them longer, thus slowing down the process. But they tend to leave a better looking finish IMHO.
I find that I can buff a car using this process in about 2 hours on average. More if its a large vehicle and/or the paint is hard or in bad shape. The trick is to make sure you do all of your correction with the rotary minus the holograms. The DA polishers make quick work of holograms.
I have SwirlX and Ultimate Compound and Megs #83. Lets say I do some error correction with the rotary, using UC, which of these do you think I should follow up with on the DA to remove any holograms etc...?
well you want to use something thats not as abrasive or has less "cut" then the compound and a less aggressive pad. so you would want to step down to a light cutting or polishing pad. and so on. the DA used with the right product will remove the swirls and such left behind by the Rotary. Ive done many cars swirl free with my rotary but it was a long tedious process. 3-5 steps and the last few steps were using light pads and low speed and then finishing by hand
By Freshblake in forum Auto Detailing 101
Last Post: 07-04-2018, 08:43 AM
By jslym777 in forum Wet-Sanding, Cutting & Buffing
Last Post: 01-06-2018, 10:00 AM
By asap2stacks in forum Auto Detailing Tools and Accessories
Last Post: 07-25-2017, 05:06 PM
By sabresfan in forum Rotary Buffers
Last Post: 09-07-2012, 01:31 PM
By surajprasade in forum Ask your detailing questions!
Last Post: 12-05-2011, 02:45 AM
