Results 1 to 8 of 8
Thread: Flex drill
    Mar 2020
    33
    Flex drill
    I just seen from P&s a flex drill with a detail brush on the end to do cup holders..is this something that's already out or coming soon product I haven't seen a flex drill or a brush that attaches like that.
    May 2013
    TN
    1,768
    Re: Flex drill
    Picture?
    Mar 2020
    33
  4. Thanks dgage thanked for this post
  5. #4
    Jan 2015
    Simi Valley, CA
    1,783
    Re: Flex drill
    Probably a little homemade ingenuity.
  6. Likes Mike Hoekstra liked this post
  7. #5
    May 2013
    TN
    1,768
    Re: Flex drill
    Haha. Yep, looks homemade but easily doable. Then again, getting it perfectly centered and balanced likely isn’t easy. Thanks for sharing.
  8. #6
    Sep 2015
    2,173
    Re: Flex drill
    Been there, done this......works with any drill. Having it centered and balanced is not really that critical, you just need it to agitate your cleaning solution and loosen up the dirt. In cup holders, you can run into some stuff that's seriously stuck in there.....that's when the steamer comes in handy
  9. #7
    Super Member Mike Hoekstra's Avatar
    May 2020
    Grand Forks, ND
    470
    Re: Flex drill
    Just an interior brush that's had the handle shaved down to fit the chuck. The torque pushes the bristles out and cleans. Great little home remedy tool.
    Owner/Operator Auto Massage LLC - www.automassagellc.com
    Custom painter and commissioned artist - www.spikedairstudio.com
  10. #8
    Re: Flex drill
    Quote Originally Posted by Blacklightn25 View Post
    FLEX makes a LOT of tools. They are also owned by Chervon their Parent Company who owns a number of smaller companies. I have a Skill Cordless Drill you see me use for cleaning tires, it's one of their brands.
    From this write-up
    Review: GYEON Q2M Tire SiO2 Coating
    Machine Application
    In the same way I like to machine scrub tires I also like to machine apply dressings and coatings, when possible. Unlike us wimpy human beings - machines never get tires and in most cases this means more consistent and uniform results no matter what the process.
    To machine apply this tire coating I grabbed a plastic bowel out of the break room and pumped a few squirts of the coating into the bowel.
    Grey Upholstery Brush
    I've removed the Aqua brush for scrubbing and replaced it with a grey brush, which is softer and less aggressive. This will work GREAT to work the coating into all the siping as well as irregular surfaces found on a tire sidewall.
    Real simply - dip the brush into the bowel to get some coating onto the ends of the bristles.
    Then let the machine take over...
    (I used the same cordless drill to machine scrub the tires to get them clean, just didn't show the picture. Used the Aqua brush for tire cleaning)
    And like others said, basically Kyle stuck a brush in the jaws of the drill and turned the brush originally designed to be used by hand into a machine brush.
    Pretty cool. Kyle be like one cool dude too.
  1. $3 Drill Brush?
    By rolop6 in forum Auto Detailing 101
    Last Post: 04-30-2013, 08:21 AM
  2. looking for advice - to drill or not to drill
    By timaishu in forum Off-Topic
    Last Post: 03-25-2012, 09:09 PM
  3. Look for something can use with drill
    By szjalo in forum Auto Detailing 101
    Last Post: 12-16-2011, 03:38 PM
  4. Flex 10.8v Drill
    By Pepperjam in forum Customer Comments
    Last Post: 01-23-2010, 11:07 PM
  5. FLEX ALi 10.8 S Impact Drill
    By Lonewolf2007 in forum Auto Detailing Tools and Accessories
    Last Post: 08-17-2009, 06:09 PM
