Results 11 to 20 of 21
    Mar 2017
    Southeastern PA
    2,480
    Re: Cleaning headlights that don’t need repair
    Essence works great to clean up the lights. Go for it.
    Bruno Soares
  2. Thanks Craig Encinitas thanked for this post
  3. #12
    Super Moderator Bobby B.'s Avatar
    Sep 2009
    2,355
    Blackfire Plex Pro Plastic Cleaner & Protectant
    BLACKFIRE Plex Pro Plastic Cleaner & Protectant
  4. Likes Coatingsarecrack liked this post
  5. #13
    Dec 2018
    7,171
    Thanks all. Will probably give essence a try and then finish up with that blackfire pro plex.
  6. #14
    Mar 2017
    Southeastern PA
    2,480
    Are you coating them car? If yes, then use Essence and coat with the same product you’re using on the paint. My lights all got cleaned up with Essence and have 2 coats of UK and a coat of Gliss. Beads just like the paint
    Bruno Soares
  7. Thanks Craig Encinitas thanked for this post
    Likes Craig Encinitas liked this post
  8. #15
    Dec 2018
    7,171
    Quote Originally Posted by BSoares View Post
    I do have about 10 mils of Cquk3 left.... or for that matter a bunch of coating lites i gotta plow through... so Essence then coat?
    Again my lights still have factory uv coat. You can ceramic coat over it?
  9. Likes Craig Encinitas liked this post
  10. #16
    May 2017
    Pittsburgh PA
    2,847
    Of course! Your paint has cc and you coat that. People coat PPF. Protect the protection. Not sure how long non-dedicated coatings last on headlights but it’s only going to help extend their life.
  11. Likes Craig Encinitas, oneheadlite liked this post
  12. #17
    Dec 2018
    7,171
    So i ordered p21s total paint cleanser to start least aggressive. Also want to test out on coated panel to see if it will remove contamination w/o hurting coating.
    The meguiars plastx looks like it would be more aggressive so that or Essence will be plan B.
    Will coat with CqUk3 or PBL surface coating once polished.
    Thanks all,
  13. Likes oneheadlite liked this post
  14. #18
    May 2017
    Pittsburgh PA
    2,847
    I didn’t mention but I use Coating Prep Polish (zero abrasives, cleaner) for newer headlights because I’m afraid of any abrasives compromising the manufacturer’s UV protection.
  15. #19
    Dec 2018
    7,171
    That was my thought. What prep do you use? I have essence which does have some cut. Thats why that and meguiars plastx are plan B and the paint cleanser was plan A as it has no abrasives.
  16. #20
    May 2017
    Pittsburgh PA
    2,847
    I have PBL, M37 and DP Coating Prep Polishes. I have always used PBL or M37 prior to my headlight coatings or whatever coating lite I’m using. And I typically wipe it on by hand, lightly with a foam applicator. Using Essence with a no-cut-pad would be fine. But when you have non-abrasive prep polish, might as well use it first.
    PlastX I only use on old headlights due to its abrasives, albeit light.
  17. Thanks Coatingsarecrack thanked for this post
  1. Replies: 21
    Last Post: 02-14-2020, 09:05 PM
  2. Chip Repair - Repair?
    By PGBCruiser in forum Wet-Sanding, Cutting & Buffing
    Last Post: 11-13-2015, 12:25 PM
  3. Cleaning condensation in headlights
    By Thenissanguy in forum Auto Detailing 101
    Last Post: 02-26-2015, 01:55 AM
  4. Glass resin filler, any way to repair the repair?
    By aim4squirrels in forum Auto Detailing 101
    Last Post: 01-26-2014, 01:52 PM
  5. cleaning headlights with megs 105?
    Last Post: 01-08-2012, 04:42 PM
