I've watched a lot of videos that demonstrate machine polishing techniques ... but they all demonstrate on large flat surface areas.
Sounds about right. It's easier to demonstrate the basics, that is the correct technique for holding and moving a polisher on a flat surface.
Are there any videos that demonstrate techniques for tight areas and non-flat surfaces?
Thanks for helping.
Yancy and I could make one. Here's the deal though, if you're using ANY brand of FREE SPINNING random orbital polisher - it's going to be "challenging" to maintain pad rotation into a convex or concave curved panle when using larger pads.
I explain why here,
The ghosting footprint and the actual footprint - Long Stroke Free Spinning Orbital Polishers
With short stroke free spinning orbital polishers and with gear-driven short stroke orbital polishers, the ghosting footprint is so small it's a
non-issue. And pad stalling with short stroke polishers is a lot less of an issue than long stroke polishers.
That is, the is
less of a chance that the panel you're buffing can cause pad stall as the pad (with free spinning short stroke tools), because the outer edge of the pad will have less leverage over the reciprocating components due to the smaller orbit stroke length than you get with long stroke free spinning tools.
Another way of saying this is,
When buffing with a free spinning random orbital polisher, when buffing curved panels - the
OUTER EDGE of the buffing pad will have
LEVERAGE over the reciprocating components and this leverage will
overcome the inertia created by the
counterweight and cause the pad to
stall or even
stop.
This is a non-issue with a gear-driven tool like gear-driven orbitals and rotary polishers.
