Re: Kwazar-Pro-Super-Foamer & Wolfgang Auto Bathe ratio?
Hi got to use Foam this weekend.
I mixed x 2 pumps of Auto Bathe into 2L litres of water and shook to mix.
Didn't appear to produce much foam?
Is there any adjustments on the Kwazar-Pro-Super-Foamer?
Where did I go wrong?
Thanks
How much is 2x pumps of Auto Bathe? You might need more soap or more pressure in the sprayer. I don’t have the same so I can’t say if it has adjustments. The iK foamer I have had 3 different tips that can give different foam each. In mine, 1oz of CG Honeydew was more than enough to produce crazy thick foam. Much thicker than the foam produced by my MTM foam cannon.
Hi thank you
x 2 pumps I believe is 2oz.
Maybe I didn't have enough pressure.
Yeah, 2oz is a lot of soap, should produce enough foam if you pump enough. Mine I pump until the bleeder valve gets ready to discharge so I know it’s at maximum pressure inside.
Also, make sure you didn’t fill the bottle all the way. It needs room in there for air to pressurize.
You can mod it to use with a compressor.
I've done it. It's not that hard if you don't mind dealing with a hose.
Thank you
Made sure only filled up to 2L mark and pumped more until a lot back pressure on the pump.
Thanks but in need it to be portable, at coin up only use there water.
I tried again and bit more of foam but still not the same as I see o n Youtube, although different Car Wash product.
Any ideas?
Thanks again
Unfortunately at this point I'm out of ideas. I use a different foamer and soap than you so it's hard to give you more tips but maybe try a different soap, Chemical Guys Honeydew Foam in a small bottle is quite cheap. That one worked great for me on my iK sprayer.
Hi i purchased two of the Kwazar-Pro-Super-Foamer, do they suppose to come with 3 different adjustable nozzles allowing for wet, normal and snow foam?
Thanks
Originally Posted by BSoares
If you plan on foaming the entire car that will take a while and lots of pumping. It does produce a lot of foam but only for a short duration. Then you have to stop and pump again, spray, repeat. It will work but probably won't be time effective. But you can count all that pumping as a gym visit then you are saving time by not going to the gym
For a whole car, a hand-held foamer is going to be a big chore. Something like the IK Foam 9, or their new IK Foam 12, would be better suited I think.
By RcAutoDetailing in forum Product Reviews
Last Post: 11-06-2011, 03:31 AM
By Big Ed5150 in forum Product Reviews
Last Post: 07-03-2011, 10:29 PM
By superd in forum Auto Detailing 101
Last Post: 05-10-2010, 02:11 PM
By MobolWerks in forum Ask your detailing questions!
Last Post: 02-14-2010, 12:59 PM
Last Post: 10-30-2009, 08:19 AM
