Re: Coating questions? Do they degrade? Are you married to them? Can you go back to a wax or sealant?
The main advantage of a coating for me is actually paint preservation. Polishing usually removes 1 to 2 microns of clear that is the accepted fact. However if I can add 1 to 2 microns of resin onto my car, I can instead be careful how I touch the car and remove as little clear as possible when I polish since most of what I remove will be the coating I applied initially.
2016 Mazda 3 Sports GT
2015 Lexus IS250 F Sport
Originally Posted by
The Guz
UFF is a sealant and CanCoat is like a lite version of a coating. It has SiO2 in it which is found in many coatings to give that more durable form of protection. It also has some fantastic water behavior in beading and sheeting. Much more so than UFF. Also the self cleaning effects are really nice. The only difference needed is a prep wipe prior to applying CanCoat.
Doesn't UFF claim 12 months protection whereas CC is 6 months? I understand the price difference now thank you, trying to figure out what I want to put on my work truck. Not going full coating because it'll get ignored and not as much care since it is an oil field vehicle
Sent from my SM-G930V using Tapatalk
minerigger
As much as I want to believe UFF will last a year I personally don’t think it will. I had it on the paint for 3-4 months and it was performing well.
Here in my area of So Cal 6 months seems to be about right. 8 would be pushing it. The thing is with UFF it’s slightly easier and faster to apply.
On the video on Autogeek’s youtube channel, Jeff states CanCoat to last around 6-9 months. I’m at around 5 months and it’s doing really well with no signs of degradation.
For that truck, I’d probably go with UFF and reapply as needed.
minerigger
I hate to say this, but manufactures claims don't seem to have much to do with the reality. Even if the claims are true, they're likely for conditions that don't exist for most of us (garaged 95% of the time and rarely exposed to weather, for example).
I understand the wisdom of removing a coating with light polishing after a year or so, and re-applying. But what if part of the car has paint protection film installed?
I’ve read a few times that running a machine polisher over PPF is a bad idea.
So if you have front-end PPF installed, are you better off just sticking with sealants and wax?
DoubleDare
I've had good success running a machine over PPF to remove very light marring.
But it had LESS to do with the machine. It had EVERYTHING to do with the abrasive technology and pad choice. I did use a free spinning oribital polisher, I forget which ones over time but either a simple ROP like the Griot's 6" ROP or the RUPES BigFoot 21.
Kind of like I always post on this forum, on FB and teach in my classes, the MOST important factor when polishing anything STARTS with the abrasive technology. It's real simple to figure out... what TOUCHES the paint first?
DoubleDare
I don't see any specific reason to do this. If you want to go with a coating, go with it. For the PPF, find a high quality one-step cleaner/wax like the BLACKFIRE One Step and "lightly" machine polish if and when needed. It seems to work really well on PPF and on paint too.
This is good to many people here seem to think that their coating is a force field that dirt can not stick to.
I know for a fact you can get road film with in 4 weeks with a fresh coat of silica wax. Even if u wash it 1x per week
Cruzscarwash
im in a group text with a few forum members and this comes up at least twice a month. ive dipped my toe in the pool of coatings on my personal vehicles but I'm never satisfied with them. i always end up going back to sealants, the overall look and fact I can better keep my car in top shape because I apply a fresh coat 2-3 times a year with a light yearly polishing to keep it looking its best satisfies me best.
I don't know if maybe I haven't found that one right coating to work for me either, I offer coatings to my customers and they seem to love them but personally I just don't, at least not yet
I usually polish every 2-3 months. I use rupes diamond ultrafine. You can use it 1x a month if you want they say
WillSports3
Not if u use a fine or ultrafine polish.
fightnews
I would think the hardness of the paint effects those conditions as well. You can probably lighty polish a hard clear coat like VW with a swirl remover and degrade very little, but the same effort applied to a Japanese car with soft paint will end up with different results.
