Re: Meguiars da microfiber pads
PC + MF pad = fantastic
Flex 3401 + MF pad = not good
JMO.
JMO.
Mark,
Have you tried the DAMF with an interface pad on your 3401?
Mark,
Nailed it!
This is what Mike P. recommends as well.
I just ordered a GG6 and MF cut and finishing pads and I can't wait to try them.
I got the 205/21 on deck.
Quote:
Originally Posted by mcate
Black isn't a color, it's a part time job.
Just a quick follow up, mid fifty's today my wife's 08 sable needed washing. So I played with a finishing microfiber pad and wolfgang finishing polish. I must say I pleased with the results, the paint is in very good condition so that helps. I did use compressed air to clean the pad after every panel it really gave my PC a new meaning. Topped it with 845 & 50/50, Meguiars microfiber pads will take your D/A to a new level.
I absolutely love and have no issue with Meguiars MF pads on my Flex. i use it constantly
Carolina`s Finest Detailing - Charlotte areas preferred CQuartz Finest Reserve & GTECHNIQ Crystal Serum Ultra coating center. STEK/Suntek PPF
www.Carolinasfinestdetailing.me
Will have to give it a try
Those microfiber pads are potent! I use the Rupes Microfiber. While I've had surprising results with Ultimate Polish on the yellow rupes mf pad, m105 on a blue rupes cutting pad obliterated 1000 grit sanding marks, in a very short amount of time, speed 4.5-5, on the 7424xp. I was shocked.
I hit it twice, but was playing around with the seasoning of the pad, and hadn't really dialed in the amounts. I probably could have done it in one polishing cycle.
Good to know! I ordered some 6/7" Rupes mf pads for the flex. Can't wait to try it out.
I used meguars damf cutting and finishing disks yesterday with d300 and d301.
The car was a MB Sprinter Van. Did half the hood and wow! 3 to 4 passes, zero dusting, medium arm speed...
I was impressed how fast I worked to a good gloss finish (not show car finish, cause it's a working van).
Does anyone know a setup faster than this Meg's MF combo?
One thing: I found the pads a little too stiff to manuever curves and body lines. Any tips on that?
Using PC polisher.
Thks in advance.
By jconley30 in forum Wool & Foam Buffing Pads
Last Post: 11-20-2017, 05:27 PM
By Jhold87 in forum Auto Detailing 101
Last Post: 03-29-2016, 01:07 PM
By Coppertop80 in forum Ask your detailing questions!
Last Post: 05-05-2015, 11:33 PM
By Goleafsgo in forum RUPES BigFoot Oribital Polishers
Last Post: 04-01-2015, 12:14 PM
By dan45hk in forum Ask your detailing questions!
Last Post: 05-29-2014, 07:39 AM
